anyone have this problem, 4v bolts
I looked at this 04 mach 1 with 37k, where the bolts are that hold the valve covers on it looks like oil leaks past them, do you think it sat around and the gaskets dried out, 37k is low but not that low, is this a common problem or a big deal? I think im going to buy it tomorow unless this is something to consider.
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune |
hmm weird
yea dont like that to much, need some input before i purchase
anyone? could you either torque them down more or remove one at a time and replace the gasket or what.
Moderator
could be,
could be oil going into the spark plug hole and then coming up through the COP cover which would indicate that the gaskets for the spark plugs are worn and need to be replaced could be oil leaking out of the PCV grommet if this is your car or a buddies just buy the valve cover gasket set which includes all of the above, bolt gaskets, spark plug gaskets, and valve cover gaskets
![]() ![]() BUILD 2 IN PROGRESS |
its a car i want to buy
Billy Weston
Its pretty normal most 4v's I have worked on get a little wet around the bolts. I just wash it off its not going to hurt it.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
Moderator
take the COP cover off and look to see if there is any oil in there as the gasket sometimes goes on the 4v just make sure to check the car thoroughly before purchasing it, but im sure you know that
#9 | |
Moderator
ok as long as its nothin major, and whats up with the 4v and the valves ticking, so many i have looked at they do and i no people on here talk about it, how is it normal or nothing to worry about, i didnt think its normal for an engine to tick.
Moderator
it the "Head Tick" if you look that up you will find alot about it out
Moderator
some got the fix and there should be a colored dot on the heads somewhere and some just live with it, but as far as I know it is normal for the 03-04 machs and termi's
2003 Mach 1 Mustang
my roomates mach was doing this the other day he just noticed it. just cleaned it and tightened the bolt down a lil more and has been fine since
![]() mostly stock 8.2@83 1/8th |
Threads Similar to: anyone have this problem, 4v bolts
| bolts | mpboy | 99-04 | 1 | March 30th, 2008 05:20 AM |
| bolts | mpboy | The Clubhouse | 4 | February 10th, 2008 06:50 PM |
| bolts | mpboy | 99-04 | 0 | February 8th, 2008 05:35 PM |
| bolts | terribleonexx88 | 5.0 Mustangs | 11 | October 29th, 2007 07:55 PM |
| could header bolts be the problem? | ddashtrois | 99-04 | 4 | March 30th, 2007 09:55 PM |
