how much boost??
Old February 17th, 2009, 04:20 PM   #1
dudelinger's Avatar
1997 Mustang Cobra SVT
soon!
dudelinger is on a distinguished road
how much boost??
I've got a D1sc intercooled 97 cobra(8.5:1 comp). So I researched, and my car was never really dialed in and I want to get the boost safe for 91 octane and have it alll tuned. I do have a 3.5 inch reichard pulley on the blower and a 6.5 inch lower pulley.Does any one with a similar setup know what ballpark psi that is?
8:1 HCI built motor, D1SC Procharged/intercooled,custom ground cams,HCI intake manifold,MSD dig ignition,KOOKs Full Lengths,MM full tubular,Pro-motion tko 600, 3" Bassani xpipe,Magnaflows,much more! 625RWHP/510RWT
Old February 17th, 2009, 05:47 PM   #2
WilltheThrill's Avatar
Saving up for another one
WilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura about
I have no idea. Just call the Procharger company tech line and ask them.
Yes those are cobra R replica mustang wheels on my 300zx
03 Cobra- gone but not forgotten
90 Nissan 300zx
00' Yamaha YZF 600
Originally Posted by '97'Cobra View Post
I was too drunk even tell which hole i was gettin after.
Old February 17th, 2009, 07:07 PM   #3
dudelinger's Avatar
soon!
ya i did, they are no help whatsoever. "oh we have no idea, not even ballpark...just look at the boost gauge"lol I guess just fill 'er up with some race gas and see what happens.
Old February 17th, 2009, 07:23 PM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
If I were you I would go to a reputable speed shop and talk to them on what you are trying to do, they should be able to provide some insight on what you should be able to do with your setup and dial it in.
BUILD 2 IN PROGRESS
Old February 17th, 2009, 07:55 PM   #5
Diabeetus's Avatar
Black 2001 Cobra
Diabeetus will become famous soon enoughDiabeetus will become famous soon enough
Send a message via AIM to Diabeetus Send a message via Yahoo to Diabeetus
Get a boost gauge, they're cheap, and do a little research on shops in your area and get a dyno tune. Dyno tuning isn't cheap, but it can save you a lot of money in the long run. Sounds like you have a nice setup. I'm jealous.
Black 2001 SVT Cobra
Solid axle
"Good judgment comes from experience, experience comes from bad jugment"
MM Cobra Club Member #1
Old February 18th, 2009, 12:02 AM   #6
dudelinger's Avatar
soon!
thanx guys. I have a lunar boost gauge on it, and I researched and found the guy that built the motor and dynoed the car. It all came down to, he said to fill it up with race gas and read the gauge and go from there as a starting point till I get to around 14-15 psi, then bring him the car in san jose to fully dyno tune it. thanx for your insights
Old February 19th, 2009, 01:18 PM   #7
dudelinger's Avatar
soon!
So,I filled it up with some 110 sunoco and hammered down...she DOES hit 21 psi like the guy said! It was a blast, but it sux cuz I do have to try and tweak the boost down about 6 pounds...What size pulley would any of you guys recommend trying to drop the boost from 21psi to my goal of 15psi? it looks like it will clear up to a 4inch (3.5inch on it right now,6.5inch crank)
Old February 19th, 2009, 01:32 PM   #8
bitemark46 has a spectacular aura aboutbitemark46 has a spectacular aura about
Biggest I've seen on a blower pulley is 3.6". I think you're gonna have to get a bigger lower pulley. Is that on a 6 or 8 rib? Any belt issues?
-Mark
-Mark-
98' N/A Cobra (Stock longblock)
11.79 at 114.64 (1.62 60ft)
Old February 19th, 2009, 11:44 PM   #9
dudelinger's Avatar
soon!
Its on a 8-rib setup with a reichard racing manual tensioner. don't u mean get a smaller crank pulley to underdrive it more...i thought a bigger lower will speed it up?
Old February 27th, 2009, 01:02 AM   #10
1997 Cobra
drtracer01 is on a distinguished road
hey dudelinger, i have an almost identical set up as you do, d-1 on a fully built motor with 3.4 or 3.5 pulley and was told it should give me 16lbs of boost. but you are seeing 21lbs with a 3.5? i am having crazy belt slippage even with a reichard racing pulley, i'm interested in that manual tensioner you are using, is it the one for the lightnings from reichard?
Old March 1st, 2009, 07:57 PM   #11
dudelinger's Avatar
soon!
here is the link to what I have on it. it is actually an ac delete.my car has no a/c on it. It worx great for no belt slippage tho, and it is going to 21psi at about 5800rpm wot.
Reichard Racing
Old March 1st, 2009, 09:21 PM   #12
1997 Cobra
ah ok, i see, i'd like to keep my a/c if possible, SW Louisiana summers are ridiculous. mine will climb to 7000rpm so quickly, probably one reason i have the belt slip, but seems like a 3.5 reichard pulley and 8 rib belt should do the trick. i had a 2.9 pulley at first and was seeing over 20lbs of boost, that's why i put on the 3.5 and have seen 14-15lbs.
Threads Similar to: how much boost??
For those with Boost... 1FastFox 5.0 Mustangs 11 October 21st, 2008 11:27 AM
boost? jtlogruss08 V6 Mustangs 2 August 20th, 2008 02:16 AM
how much boost with no IC 20gtvert03 99-04 10 June 29th, 2008 07:39 PM
How Much Boost? Baja_XJ 2.3 Mustangs 21 December 22nd, 2007 09:48 PM
Turbo Boost vs Super Boost droppedbass87 General Tech 12 October 16th, 2006 10:56 AM
