Changing plugs
Old February 24th, 2009, 02:53 PM   #1
2003 Mach 1
crodrc51 is on a distinguished road
Changing plugs
Did a search, but wanted to be more specific on the details. I ordered NGk non platinum from Lethal Performance. Last time I performed plug change was on a 302 windsor. To take off the coils, do you just pull up on them, or are they threaded on? Do you coat the threads on the new plugs with antiseize? Is it just that straightforward for the change; covers off, coils pulled and keep in line, change plugs, attach coils, replace covers and I'm good?
The reason I ask is that the local Ford dealerships want to charge 300 clams for the work. I wanted to see if there was anything else involved, but Ford says nothing else that is special. Thanks for any advice.
Old February 24th, 2009, 04:52 PM   #2
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
Coil pack pull right off and yes, use a small amount of anti-sieze. Make sure when you put the cover pack on that the rubber grommet is in place so no watter gets inside.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old February 24th, 2009, 06:07 PM   #3
o2gtstang is on a distinguished road
+1 what he said!!
thanks for the sig Zatrekaz
Bowties are for Gay Guys!!!
Old February 25th, 2009, 02:19 PM   #4
2003 Mach 1
Thanks for the response!! I will make sure that grommet is good.
Threads Similar to: Changing plugs
Changing the spark plugs zinc02GT 99-04 14 February 24th, 2011 10:54 AM
Changing Shark Plugs PowerShiftz02GT 99-04 34 April 12th, 2008 12:56 PM
Changing The Plugs JASonic V6 Mustangs 31 April 8th, 2008 02:42 PM
Was Changing Plugs And... 1979rs/z28 99-04 9 December 19th, 2007 12:38 AM
need an easy way of changing my plugs in my 2000 (v-6) timwade V6 Mustangs 1 February 25th, 2007 05:01 PM
