Building a 4.6 for boost
So my stock bottom end took a dump on me a two weeks ago today. Not completely sure the root cause of the failure, but earlier this week I did find a nice hole in the valley of the block. (I'll take pics and post soon.) I have spent the last couple of weeks getting money together and trying to figure out wtf I want to go with. Here is what I have so far: '99 Cobra teksid block that's been bored .20 over and is ready for a new rotating assy. I'm going to use my stock Mach 1 heads on this block, along with keeping the Eaton. Has anyone here done a stroker kit on one of these blocks or read about someone that has? I have been thinking about getting a stroker rotating assy, but am not completely sure that it would really help me out. If not, then I may use my stock crank and just put some forged rods/pistons in. Looking for between an 8.5 and 8.9 compression ratio. Any advice as to what might be good to go with would be appreciated.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
i would personally just go back with a 4.6 instead of the stroker. i would do a little massaging on the heads, reuse stock crank (especially if its forged), get a 15cc or so dished piston, h-beam rods of your choice, have a machine shop prep assembly, and you will be set.
dont forget the oil pump
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 |
new pump or the billet gears?
Oh and I have ABOUT $ 1600-1700 to spend on a rotating assy. I am going to pull the motor this weekend and should know sure by next week if my stock forged crank is usable. Either way, I think I might prefer to get a rotating assy. if I can afford it and sell off the stock crank if it is good just so I can get this going. Thanks for the advice so far. Is there a reason behind forgetting the storker? Pointless? No power gain? Unreliable? Thanks. Oh also, I'm not looking to make 800 hp. In the end, I'd like to port/pulley the Eaton down the road and make 470-500 to the wheels.
![]() MM Cobra Club #42 417 HP & 413 TQ (Old #s) 422 HP & 453 TQ (New #s) 492 HP & 502 TQ (with Posi and 2lb lower) Last edited by Reloaded; March 20th, 2009 at 04:50 PM. |
mm's nitrous mod
2000 mustang gt
either. billet gears are for hardcore set ups or for those that are just worried about failure. a lot of guys just go with 03/04 cobra oil pumps.
I just checked the Ford parts catalog. The oil pump out of a Mach 1/'99-01 Cobra/03-04 Cobra are all the same part number.
mm's nitrous mod
2000 mustang gt
we installed the mmr oil pump in doc's car, i will probably do the same in my car this summer/fall.
pull it apart and see whats actually broke , buy just what you need and check companys like Modmax , MMR , DSS for the best deals on what you wanna put in it , I lost 2 pistons in my GT over a year ago and reused the stock crank and put H beam MMR rods and Manley pistons in for little over 1000 .......upgraded to ARP hardware while I did that as well ....put 03-04 cobra oil pump and pickup in it for cheap upgrade
Ok cool, just checked their webiste. Looks like I'll pick one of these up along with my internals. Thanks for the heads up!
#10 | |
BTW, I'll be contacting you for a new tune pretty soon here.
I.D.G.A.F.
I also installed the MMR billet pump in my car as well.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
Moderator
same here. when i did the rebuild i didnt want to skimp out on anything.
![]() ![]() BUILD 2 IN PROGRESS |
Threads Similar to: Building a 4.6 for boost
| building AOD | 88Saleen | 5.0 Mustangs | 31 | September 17th, 2008 06:32 AM |
| building my 97 5 speed | InSaYnE | V6 Mustangs | 17 | January 20th, 2008 11:38 PM |
| Help building my 86 lx 5.0 | dwest | 5.0 Mustangs | 4 | November 25th, 2007 12:48 AM |
| Building The 96 | 96gtstang&V6 | 96-98 | 3 | November 21st, 2007 10:20 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
