99 Cobra / 96 GT vert.
N/A
Opinion on ebay turbo kit?
I want to turbo my 99cobra and would like to do the work myself. I do not have a lot of cash to drop on a kit that is expensive from the top retailers. I seen a kit on ebay for $1699. It had a few things that needed to be obtained before it was considered a complete kit. I am not looking to make huge numbers, just a little extra boost and the bragging rights of having a turbo cobra, not to mention that I did the work myself when chatting it up at the local spot. I am somewhat mechanically inclined. I also have a few friends that are mechanics. I guess what my main question is, is it worth it to get these extra parts in addition to the turbo kit for an self-install? Thank you for all feedback in advance.
Here is the list of the items included: GT45 TurboCharger 700-1000 HP Capable Wet Float Bearing External Wastegate Oil Cooled Center System Compressor (4 3/16th's Inlet, 2.25 Intake Inlet, 3.25" Outlet Diameter, 69 Trim, .66 A/R) Turbine (4" Outlet, T4 Flange, 3.5" V-Band downpipe Flange, 92 Trim, 1.05 A/R) 68.7 MM Inducer Compressor 97.8 MM Inducer Compressor 87.4 MM Exducer Turbine 77 MM Inducer Turbine Large Bar and Plate Intercooler 31x12x3 Bar and Plate Intercooler 3 Inch Inlet and Oultet with 2x 3" to 2.5" reducer Coupler 150 to 130 Degree Temperature Drop Bolt On Custom Turbo Manifold Stainless Steel Turbo Manifold for Mustang 96-04 V8 4.6L Cobra DOHC High Resistance to Heat - Made to last - Custom Turbo Manifold Uses T4 Flanged Turbos Comes with everything pictured as well as x3 2.5" Stainless Steel V Clamp and x1 3" V clamp Direct Bolt on to ALL Mustangs 96-04 4.6L V8 Cobra DOHC Stainless Steel 2.5" Connector Pipes Also comes with 3" Downpipe Requires D&D Style K Member for fitment NOTE: 96-98 Mustangs require relocating of coil pack. Universal Piping Kit 2.5" Intercooler Piping ( Aluminum ) 8 pieces, 2 u bends, 2 straight, 2 45 degree, 2 90 degree 16x 2.5" T Clamps 3 Ply Silicone Hose Items Included with Kit (Picture): (color may vary from picture) Type RS Blow off Valve 38mm Wastegate Boost Controller Turbo Timer Oil Return Line Oil Feed Line All necessary V clamps Radiator Fan to Increase Cooling 30 Row Oil Cooler Here is the list of items required to complete install: Downpipe requires additions piping to collectors ($400) D&D Style K Member Air Mass Sensor Bracket, Mustang 96-98 Requires Coil Relocation Kit Fuel Management and Engine Management system upgrades required |
i heard the piping is good on the turbo kits. buy everything else separate
http://www.cardomain.com/ride/3112249 |
i don;t think i'd trust the ebay kit
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
Authorized Vendor
![]() Join Date: Sep 2008
Do you have a link? A lot of the kits out there use Chinese knock offs of Garrett turbos. I've seen complaints about these having issues with turbo oil seals, header fitment, and the headers not holding up very well. But without knowing anything about who's selling it, it will be hard for me to tell.
Threads Similar to: Opinion on ebay turbo kit?
| opinion on Hellion turbo kit | silverstang | 2005 - 2010 | 6 | July 7th, 2008 05:56 AM |
| Turbo kit on Ebay? | The Novice | 5.0 Mustangs | 11 | May 28th, 2008 03:55 AM |
| Ebay Turbo Kit? | The Novice | 5.0 Mustangs | 10 | March 21st, 2008 02:43 AM |
| Ebay Turbo | Drick | 5.0 Mustangs | 74 | March 20th, 2008 01:32 PM |
| CUSTOM TURBO KIT ON EBAY...$999.99? CHECK IT OUT | adamo41188 | 99-04 | 3 | July 4th, 2007 02:12 PM |
