BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Cobra Weight and Times
What are the weight/time specs on the 94-95 Cobra,96-98 Cobra, and 99-04 Cobra.
I know the 03-04 can do 12.9 to 12.7 stock depends on hooking and tires with a good driver(decent). I know I could look it up but I don't know if I am looking at false info on the websites. I rather hear it from the Owners mouths themselves. so just 1/4 times and weight......... thanks alot
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
BYAHHHH!
2001 Mustang GT
13.874
deciding to do it myself. please read over and correct anything you see that may not be correct
1995 SVT Cobra- Engine-5.0L 302ci V8 compression-9.0:1 Horsepower-240 hp @ 4800 rpm Torque-285 lbs-ft @ 4000 rpm Transmission-Borg Warner T5 Five speed Driveline-8.8" Solid axle 3.08:1 ratio w/Traction Lock Weight-3326 1996 SVT Cobra Engine-4.6L 281cid DOHC Modular Compression-9.85:1 Horsepower-305 hp @ 5800 rpm Torque-300 lbs-ft @ 4800 rpm Transmission-Borg Warner T45 Five speed Driveline- 8.8" Solid axle 3.27:1 ratio w/Traction Lock Weight-Coupe :3391 Conv: 3531 1997 SVT Cobra follows 1996 Cobra 1998 SVT Cobra follows 1996 Cobra 1999 SVT Cobra Engine-4.6L 281cid DOHC Modular Compression-9.85:1 Horsepower-320 hp @ 6000 rpm Torque-317 lbs-ft @ 4750 rpm Transmission-Tremec T45 Five speed Driveline-IRS 8.8" 3.27:1 w/traction lock Weight-Coupe: 3430 Conv: 3560 2001 SVT Cobra follows 1999 Cobra 2003 SVT Cobra Engine- 4.6L DOHC Eaton S/C Compression-8.5:1 Horsepower-390 @ 6,000 rpm Torque-390 @ 3,500 rpm Transmission-TTC T-56 6-speed manual Driveline-8.8-in. ring gear with 3.55:1 limited-slip differential, aluminum case Weight-Coupe 3,665 lb. Convertible 3,780 lb. 2004 SVT Cobra follows 2003 Cobra hope this help anyone like it did me
so what about a cobra w/ solid axle?
01 cobras have 3.55 gear and t3650(most/some)
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 |
97 Cobra
96-97 had return style fuel system
98 was return as well but used new style pumps/mounting for the transition to returnless 99-04 was returnless. 99 has 28 spline IRS 2001 has 31 spline IRS 03/04 has 31 spline IRS My 97 Cobra was listed as 3375lbs. I think it changed slightly across years considering things changed such as the radiator to fix 96 heating problems, clock location, strut tower braces, etc. I ran a 12.8 on stock drivetrain with some extreme weight reduction. I've pulled weight since then too and I bet she will be faster by a tenth or two.
Converted to the Dark Side. 06 Apex Silver Evolution IX GSR - Turboback Exhaust, Tune - Wideband O2, Trustz backlight gauges, Apexi turbo timer - Stock wing, but soon to be wingless. - Guessing 280-310 at the wheels. 02 Red Escape V6 4x4 Last edited by acidtonic; April 1st, 2009 at 10:06 AM. Reason: added info |
#5 | |
BYAHHHH!
2001 Mustang GT
13.874
Also I have Cobra's with the solid ass. the 95-98 Cobra's do. Times not worth doing. go to Dragtimes.com if concerned. Also not worried about spline.(hint the title) the driveline, tranny, and etc were just extra I added.
#6 | |
97 Cobra
Good luck.
Converted to the Dark Side. 06 Apex Silver Evolution IX GSR - Turboback Exhaust, Tune - Wideband O2, Trustz backlight gauges, Apexi turbo timer - Stock wing, but soon to be wingless. - Guessing 280-310 at the wheels. 02 Red Escape V6 4x4 |
#7 | |
#8 | ||
BYAHHHH!
2001 Mustang GT
13.874
01 has 3.55 and t3650? thought its 3.27 and t45
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune |
#10 | |
BYAHHHH!
2001 Mustang GT
13.874
Threads Similar to: Cobra Weight and Times
| 97 Cobra Weight Reduction Pics. | acidtonic | 4V / SVT | 79 | September 24th, 2009 04:06 PM |
| 2001 Cobra Times? | stangballer | 4V / SVT | 11 | January 5th, 2009 11:20 PM |
| 2001 Cobra Questions and Times | stangballer | Modular Mustangs | 0 | January 5th, 2009 10:34 PM |
| Bolt-On 94 Cobra Times? | stangballer | 5.0 Mustangs | 9 | December 18th, 2008 03:07 PM |
| 01 Cobra 1/4 mile times | N02coupe | 99-04 | 8 | August 26th, 2006 09:29 PM |
