Question for the 4V crowd (03 Cobra) - Page 2
Old April 20th, 2009, 08:49 PM   #21
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Originally Posted by C MY 4D View Post
Drag radials aren't bad in the rain. It's the drivers that have an issue. You just have to drive like you have some sense. Hell the time it snowed here this year I drove to work on Bald Mickey Thompson drag radials without an issue.
What did you get? A half inch?
If it's cold out I have a hard time getting traction with the 4.10s. I don't know how the IRS will handle it as I haven't driven a car with it. And to top it off you're making more power than I am. You should take your own advise and find a local who has gears and see if you can take a ride or drive their car.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old April 20th, 2009, 08:58 PM   #22
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Drive it for what? I have the 4.10s in a straight axle.
TT Build in progress.......
Old April 20th, 2009, 09:00 PM   #23
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
The 2nd paragraph was for the OP. The first line was you.
Old April 20th, 2009, 10:21 PM   #24
1Badsnake's Avatar
2003 Mustang Cobra
1Badsnake is on a distinguished road
How tall of a tire C MY 4D? Do you have rims bigger than 17 x9 ? What combo are you runnin? I don't have any problems with traction and mine is still the irs. I too drove to work in the snow when others with 4x4 couldn't, what a joke. You are also right where the driver is concerned, if you drive sensibly you will be rewarded. Kind of like the moron driving 100 on rain soaked 64 and crashes head on and dies, if he were sensibly driving he would probably be alive today.
MM Cobra Club #17
Old April 20th, 2009, 10:27 PM   #25
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
On the street I'm still running 275/40R17s. At the track I was running 26x10.5x15. I'll be switching up to a 28x10.5x15 to get the few extra MPH I need and it will help increase the footprint. So with the new suspension and tires my 60 foot should be alot better this year.
As for the engine it's still only a 2.8 pulley, JLT High boost RAI and a canned tune.
Old April 21st, 2009, 06:18 PM   #26
2003 Cobra
1StockGT is on a distinguished road
Send a message via AIM to 1StockGT
This is true, but I'd rather be safe then sorry. Eventually I'll get a beater and slap some drag radials on.
Old April 24th, 2009, 03:36 AM   #27
Diabeetus's Avatar
Black 2001 Cobra
Diabeetus will become famous soon enoughDiabeetus will become famous soon enough
Send a message via AIM to Diabeetus Send a message via Yahoo to Diabeetus
1Badsnake, 4.10s are fine as long as you dont boost the hell out of it. If you want to go turbo, 3.55 is the lowest you want to go. 3.27s would be even better. This is because a turbo needs to have a load on it to build boost. With 4.10s and a turbo you would be out of RPM and have to shift before you made any boost.
But if you're stickin with your stock blower, even if you pulley it, 4.10s should be fine. You throw more than around 18lbs of boost at it and you're gonna want 3.73s or 3.55s. And with the 4.10s, I would recommend running a 28 inch tall tire at the drag strip.
Oh and you're carrier is already 31 spline, but the level 5 half shafts will surely help keep you on the road and off the jack stands. Install a diff cover brace while you're at it too.
Black 2001 SVT Cobra
Solid axle
"Good judgment comes from experience, experience comes from bad jugment"
MM Cobra Club Member #1
Old April 26th, 2009, 12:35 AM   #28
1Badsnake's Avatar
2003 Mustang Cobra
"Oh and you're carrier is already 31 spline, but the level 5 half shafts will surely help keep you on the road and off the jack stands. Install a diff cover brace while you're at it too."
What do you mean by they are already 31 spline? All the spec sheet says is 26 spline on the driveshaft and 26 spline on the half shafts. I am SOOOOO confused now? If you can give me a reference for this info I would be greatly appreciative.
MM Cobra Club #17
Old April 26th, 2009, 09:10 AM   #29
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
not the half shafts, and the driveshaft but your actual rear end components, are 31 spline. The 2v's and previous 4v cobras have 28 spline rear end components.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old April 27th, 2009, 09:52 AM   #30
1Badsnake's Avatar
2003 Mustang Cobra
Which components? I have 3.73's in now with stock shafts. Fill in the blanks for me. I assume that the gears are 31 spline and all I need to upgrade would be the 31 spline half shafts. Does that seem right?
MM Cobra Club #17
Old April 27th, 2009, 01:13 PM   #31
Diabeetus's Avatar
Black 2001 Cobra
Your half shafts are 31 spline. The '01, '03 and '04 Cobra all have 31 spline half shafts from the factory. This means that where they slide into the carrier inside the rearend housing, they have 31 splines. Gears dont have splines. The ring gear bolts onto the limited slip carrier. Do yourself a favor and pick up the Haynes manual, or start reading Muscle Mustangs & Fast Fords or 5.0 Mustang, and get some basic knowledge under your belt. It will help you understand a lot about your car.
Solid axle
Old April 30th, 2009, 12:03 AM   #32
1Badsnake's Avatar
2003 Mustang Cobra
Diabeetus, If the stock half/shafts are 31 spline why would I need to upgrade the to level 5 shafts? Thanks for your input, I just got a manual. I work in surgery and have to see patients in the office , so I don't have alot of time to screw around with working on the car. I usually just pay for the work to be done. I know that is sad, but I just don't have the time. Maybe after I read some info, i'll try some of the basics.
MM Cobra Club #17
Old May 3rd, 2009, 10:19 PM   #33
2003 Mustang Cobra
t-man2 is on a distinguished road
Well mine has the stock 3.55's and I ran 11.7 in the quarter mile with drag radials. When I put on my Kenne Bell I just ordered I should be high 10's maybe. I'm keeping stock gears on that setup as well.
Old May 5th, 2009, 11:11 PM   #34
Jim03SVT's Avatar
2003 Ford SVT Must Cobra
Jim03SVT is on a distinguished road
Send a message via Yahoo to Jim03SVT
I went from 3:73's to 4:10's and loved it. After about a year I put 4:30's in.. I love it way more!!
Jim03SVT
Old May 6th, 2009, 05:29 PM   #35
2003 Cobra
The Level 5s are stonger.
Old May 12th, 2009, 02:24 PM   #36
WeaponX_Perf is on a distinguished road
+1
3.27's are ideal with the turbos, 4:10's will kill your powerband with a TT setup.
Old May 12th, 2009, 02:26 PM   #37
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
I run 4.10s..... Currently at the track I am bouncing off of redline at 125 mph with a 26" tire. It will be getting some 28s this year.
i have heard t-56's are none too happy about shifting with 4.10's and a 28" tire. part of the reason i will stick to my 3.90's and a 26". i trap about 127-129 and hit the traps at 6200rpm in 4th gear.
MM Cobra Club #25 My Autolog Profile
Old May 29th, 2009, 05:29 AM   #38
1F8LSNK is on a distinguished road
stay with the 3.73's..unless ure running a 28 inch slick you WONT HOOK...i am mid 660's rwhp and 620's rwtq and blow the tires off any drag radial i put on.. and i had this setup with my IRS and my SRA.. I have to leave just above idle and have to slip the clutch even then..
Old May 29th, 2009, 03:56 PM   #39
2009 ROTY
2003 SVT Cobra
11.07@127
Originally Posted by Smoothgrandmama View Post
If nothing else you could go with 3.90s or 88s
this is the gear i use, but only motive makes it, and its a whiney gear. i have heard the the t-56 is fun to shift under power with a 28" tires and 4.10's, so i have never changed mine out. plus on a 26" tire with my 3.90's i hit the traps right at 6300rpm's. cannot complain about that one!
Threads Similar to: Question for the 4V crowd (03 Cobra)
6ers crowd around itschristorres8 The Clubhouse 18 September 1st, 2008 04:54 PM
where is the MM crowd (NJ) jersey98gt Northeast 4 November 3rd, 2007 01:11 PM
The IT Crowd MicronXD The Clubhouse 10 August 10th, 2007 03:23 PM
a little help from the NY crowd GTsetGO Northeast 2 August 5th, 2007 12:37 AM
Joining the crowd D-Brow Visual 5 June 15th, 2007 03:58 PM
