1992 Lx
11.39@119.24
Those who have done cams/timing set
Have a write up? fluffy i know you did it, in a few months or so i plan on doing some 98 cobra intake cams and figured i might as well do the whole timing set up since the car has 69k on her, just looking for a detailed write up and cant find anything.
dont know how the timming goes but i can do one on how to take it apart, i have pics
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 |
i just replace a tensioner
Bearer of Bad News
I has mustang and legacy.
Slower than my Ruger.
I don't have a write up... my friend has some software that had every step....
What I replaced was the entire timing kit and the damper. You'll need a special tool for pulling the damper. Since you're changing cams, you won't need the cam tool set to hold the stockers in place. As for what needed to be removed to get the the timing cover and valve covers off, we had to drain the A/C and radiator. We removed the hood scoop, CAI, Hyrdoboost, A/C compressor, Power Steering Pump, radiator fan, spark plugs, throttle body, and then the valve covers. We also had to disconnect the fuel... just so you know, you're probably going to spill a bit of liquid into your engine bay : D Good times! In order to get the hydroboost out you're going to have to get under your driver's side dash and pull a few bolts for the brakes. It's a pain in the ass. Once you get all of that shit off, you'll need to pull your serpentine belt and pullies off. Then you will pull your timing cover off. The timing kit itself isn't that difficult to take off and replace. It's fairly straight forward and some of the parts are labeled for you. As for replacing cams, I have no idea how to do that part, nor do I have any experience degreeing cams. I've read a couple write-ups on how to do it, but that's the extent of my knowledge on it.
~MOD NUTSWINGER~ My Tongue Soothes Razorburn ![]() STOPSAYINGFAIL.COM EVERY FART IS A GAMBLE Just Think Of Me As A White Blood Cell.
Bearer of Bad News
BTW, PM sent : D
Also, here's a thread I posted on it with a couple pictures. Not much though... Timing.
i didnt touch the a/c, radiator, spark plugs or fuel. didnt even take the oil out and the power steering pump was unbolted and moved to the side
#7 | |
Bearer of Bad News
We tried taking the valve covers off by skipping a couple steps, but it wouldn't happen. : (
wait i did drain out the radiator
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 Last edited by 99blkcobra; May 28th, 2009 at 01:48 PM. |
1992 Lx
11.39@119.24
when i say timing set, im talking the chain guides (i think thats what their called, the tensionors?), sprockets and timing chain, the only thing im confused about and my friends scared to do (hes a tech, but not a 4v tech lawl) is putting the new intake cams in right, as in timed right
1992 Lx
11.39@119.24
and 99cobra thanks for all the pics!
MM's Orangest
2004 Mach 1 Mustang
Good luck with the cams. I just bought some 98 intake cams myself.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
1992 Lx
11.39@119.24
do you plan on doing the install??
i dont think it should be that hard im getting cams later on and i plan on installing them myself.
If you guys do it ur selfs can u try to get some pics on how to install the cams, thanks. Ill see if i can find something
#14 | |
1992 Lx
11.39@119.24
![]() we still gota do my headers/clutch here in a few weeks and i wana have a tune and full boltons before i buy cams
why not do the tune after cams?? im waiting on my tune
1992 Lx
11.39@119.24
retune shouldnt be more than a couple hundred bucks, i dont wana drive around with long tubes, rai, and a spacer too long without a tune
#17 | |
1992 Lx
11.39@119.24
see that makes me nevous
car drives fine, its bored .20, it has aluminum flywheel driveshaft, 4.30 gears, steward water pump, jlt cai, upds and someone other things cant remember.
oh long tube mac headers, o/r h pipe, stage 2 steeda clutch.....
1992 Lx
11.39@119.24
have you checked your af ratio?
Threads Similar to: Those who have done cams/timing set
| my timing is set at 20 atdc | 89Domindart | 5.0 Mustangs | 21 | May 2nd, 2009 09:23 AM |
| timing chain set | Bills96cobra | 96-98 | 0 | March 29th, 2009 04:55 AM |
| Nitrous and what should I set my timing at | Steves LX | General Tech | 2 | September 28th, 2007 06:51 PM |
| 4.6 V8 4v timing chain set-up | Mauriello Motorsport | 4V / SVT | 2 | May 25th, 2007 11:10 PM |
| Check/Set Timing | BoomerSixZero | Classic Mustangs | 7 | February 24th, 2007 01:24 AM |
