Pulleys
Old June 2nd, 2009, 10:04 AM   #1
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
Pulleys
Ok guys the bug is starting to get to me again, and the Cobra can't stay stock for much longer.
I've been looking at pulleys, and have no clue where to start. I don't know about how much boost each pulley will make or anything, or what brands to go with, and which to stay away from.
So I could use some help here guys. Thanks.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old June 2nd, 2009, 11:10 AM   #2
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
There are a lot of options for pulley. Upper or lower, what brand, etc.
You can increase boost with a combo of either. I personally just have an upper (2.93 which is typically just the next size down from the stocker). Right now I am making about 12# of boost. I would like to in the future add a 2# lower. I honestly think that a 4# would be too much for the Eaton and heat soak would start to be an issue even with the port job, but I'm still looking into it.
As far as brands you have a lot of choices. I have Billetflow and I would recomend that. I don't think I have heard a single bad thing about their pulleys. You want something that wouln't slip and Billetflow seems to be one of the best.
If I where you I would look at idlers and tensioners. Basically anything you can do to keep your belt from slipping.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old June 2nd, 2009, 11:26 AM   #3
2003 SVT Cobra
Every car and setup is going to be a little bit different, but here is a basic breakdown.
2.93-12#
2.8-14#
2.76-15#
Than add the lower. Like a 2.93 (12#) + 2# lower= 14# of boost. Like I said, this is just a starting point to give you an idea. I don't want you to think that adding a 2.93 upper and a 2# lower will give you 14# guaranteed.
And it is up to you to see how much you want to push the Eaton. They are not known for efficiancy and are called 'Heatons' for a reason. A port job will help. That's is the problem I am facing. I really don't know if I want to run 14# or 16# (ported blower-will be on pump gas 99.999999999999999999999% of the time)
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Old June 2nd, 2009, 01:27 PM   #4
Zoolander
iTrader: 5 reviews
Ok thanks. I was going to head down to JLT (about a 5 min drive from my house) to pick up a rai, and possibly a pulley, but they mostly have metco. I also think I want to go the whipple route somewhere down the road, but will pulley the stock eaton for now.
Gotta get rid of the strut tower brace though.
Thanks man.
MM Cobra Club #18
Team Tini Racing
Old June 2nd, 2009, 08:14 PM   #5
2003 Cobra
1StockGT is on a distinguished road
Send a message via AIM to 1StockGT
I have all Billetflow on mine. I have a 2.76 and the 4 piece idler set. Metco costs a little more, but I'd say that they are a little better quality, but by no means is there anything wrong with Billetflow. With the 2.76 and the Stiegemeier stage 4 ported blower I make 14# of boost. Do you have a hand held tuner? I have a JLT cai on mine. Tucker is a real stand up guy.
Old June 3rd, 2009, 12:18 AM   #6
svt2ner is on a distinguished road
Tucker maybe give you a deal if you bought the sct xcal, pulley and idlers. Dont forget the plugs.
03 cobra #675
Old June 3rd, 2009, 01:11 PM   #7
Reloaded's Avatar
2004 Mach 1
Reloaded is just really niceReloaded is just really niceReloaded is just really niceReloaded is just really niceReloaded is just really nice
Send a message via AIM to Reloaded
I'm running billetflow pullies as well. A 2.76 upper, no lower and the 4 piece ilder kit. I love billetflow's stuff.
Don't forget that you'll need a tune as well obviously when going up that much in boost.
Also, some people run into belt slip some don't. I had a bit of belt slip with the recommended 75.1" belt and snub ilder with a 2.76. Going to try a 74.5" belt instead.
MM Cobra Club #42
417 HP & 413 TQ (Old #s)
422 HP & 453 TQ (New #s)
492 HP & 502 TQ (with Posi and 2lb lower)
Originally Posted by BuRnIn_YoUrS View Post
Dude...it takes alot to make me gag...
Old June 3rd, 2009, 04:20 PM   #8
Blutooth's Avatar
2004 Mustang Cobra
Blutooth is on a distinguished road
Last year I was running a 2.76 BF as well. Had no belt slip, 4 piece idlers and then dyno'ed on a mustang dyno (14-15#). I personally wouldn't use a handheld tune (Manufactured Tune). Each car is a little different, and the best results is when it's customized to your car specifically. Thats just my 2 cents..... Good luck!
Old June 5th, 2009, 01:28 AM   #9
olskool's Avatar
Comming soon VERY soon
olskool is on a distinguished road
Got the Billet Flows on the 03 cobra no problems at all and its driven like its stolen all the time i think were pushing in the neighborhood fo 15PSI but we have the full kit. I would recomend them they seem to work great for us.
" i dont worry about history there is no future in it" Bill the leadslinger hines
Ecoteroism Rocks
Old June 5th, 2009, 01:33 PM   #10
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
billetflow all the way! they make some sick stuff. its well worth the money.
and stock cobras exist?
MM Cobra Club #25 My Autolog Profile
Old May 3rd, 2010, 11:09 PM   #11
pete3323 is on a distinguished road
Nice RACK!!!!!!!!!!!!!!!!!!!!!!
Threads Similar to: Pulleys
pulleys 6banger96 V6 Mustangs 0 March 30th, 2008 02:23 AM
Idler Pulleys Underdrive pulleys? 96GtGoodz 96-98 4 November 19th, 2007 11:02 AM
so i got my pulleys mustang1072 V6 Mustangs 49 May 29th, 2007 12:15 AM
pulleys mustang1072 V6 Mustangs 16 May 21st, 2007 09:49 AM
