Any ideas?
Old June 6th, 2009, 05:54 PM   #1
rob madison is on a distinguished road
Any ideas?
Yesterday i was driving and all of a sudden my car just died on me. I replaced the battery a month ago, and i'm wondering could my alternator cause my car to shut down suddenly.Also is it possible to push start it eventhough it wouldn't crank up? would the alternator cause it not to be started? my car is a 98 cobra, any suggestions what could be the problem?
Old June 6th, 2009, 06:08 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
if your alternator is bad then it is not charging the battery at all. you can run on it for a certain amount of time until your completely drain the battery thus not being able to start it or anything. check the connections first. then either test it yourself or get a new battery and drive it to an autoparts store will they will test it for you, usually for free. it should read 11.4-12v with the key off and 13.4-14.4 with the engine running. if it is not reading those then your alternator is gone
BUILD 2 IN PROGRESS
Old June 6th, 2009, 06:08 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
also check all of your grounds
BUILD 2 IN PROGRESS
Old June 6th, 2009, 07:32 PM   #4
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
+1...just went through that with a buddy. But Primo knows that...he did the testing.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old June 6th, 2009, 09:30 PM   #5
1999 cobra
99blkcobra is on a distinguished road
Send a message via Yahoo to 99blkcobra
is ur check engine light on?
1999 Mustang Cobra (rebuilding, someday...)
1996 civic dd
[/SIZE]
MM Cobra Club #3
Old June 6th, 2009, 11:32 PM   #6
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
BUILD 2 IN PROGRESS
Old June 7th, 2009, 02:27 PM   #7
Mustang RacR94's Avatar
99 cobra
N/A
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
is it not cranking or just not starting, and yes It could be an alternator, do you have a multimeter with a amp clamp? if not the test for the alternator can be done at a dealer or garage. but if you charge the battery for a long time and it starts again then its prob the alternator
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Old June 8th, 2009, 11:08 PM   #8
TUGGER's Avatar
2003 SVT Cobra Vert
TUGGER is on a distinguished road
2 days ago my car started doing something similar. When I came to a stop at stop sign/red light my cars RPMs would drop way down and the car would shut off. I would restart it and it would fire right back up. Car would idle fine but it was when I was bringing it to a stop that the RPMS would drop way down like it wanted to die out. Turns out the Idler Control Valve went out. I'm having it replaced tommorrow. Don't know if this helps or is similar to your problem. I figured mine was alternator or battery related issue but both checked out fine. Hope this helps.
2003 SVT Cobra Vert
Magnaflow Catback, K&N CAI, 18" Replica Chrome Bullitts, Diablosport 91 Octane Performance
Old June 9th, 2009, 12:13 AM   #9
tweeters97's Avatar
1997 Cobra
13.62@104
tweeters97 is on a distinguished road
+1 my car did the same. i replaced iac and no problems since. take your car to a parts store where they can check the alternator for you. i work at advance auto and we test the battery and alt at the same time on our machine. we test the alternator while the car is running to check it under a load. testing it with a voltmeter is not difinitive enough with all the electrical components and ecu that has power feeding it.
MM Cobra Club #29
Who are you?????? Choose your destiny!!!!!!
Old June 9th, 2009, 05:02 PM   #10
TUGGER's Avatar
2003 SVT Cobra Vert
They checked both under full load and said all was good. I'm going to see how it runs with the new iac but I don't think I'll have any more issues.
2003 SVT Cobra Vert
Old June 10th, 2009, 12:24 AM   #11
tweeters97's Avatar
1997 Cobra
13.62@104
cool man. good luck. let us know how it turned out.
MM Cobra Club #29
Old June 11th, 2009, 01:33 AM   #12
TUGGER's Avatar
2003 SVT Cobra Vert
Got the car back today and it is running 100 times better. I think the idler has been going out ever since I bought the car last september.
2003 SVT Cobra Vert
Old June 17th, 2009, 11:34 AM   #13
I took the alternator off and got it checked, it was fine. Also my battery was down to about 59%, i took it back and got it charged up complete. Still wasn't able to start it. I tried push starting it and when i popped the clutch, it just shook a little and nothing happened. The problem that i'm having is i can't get it started to get the alternator checked in the car. Would the idle control valve stop it from being push started? Also when it first shut down i was able to start it and it did idle a little and that was that.
Old June 17th, 2009, 12:42 PM   #14
phoenix99's Avatar
phoenix99 is on a distinguished road
your theft light is flashing?
check your sparkplug or your crank position sensor too
Addicted to adrenaline
Forged 5.4 4v with B heads and nitrous. Tuned by me
Old June 18th, 2009, 07:47 AM   #15
Molitor's Avatar
2004 Mustang Mach 1
1994 Dodge Ram 5.9L 4WD 1976 Monte Carlo
Molitor has a spectacular aura aboutMolitor has a spectacular aura aboutMolitor has a spectacular aura about
I remember reading a thread awhile back that sounded alot like this, it ended up being the guys key was cracked, so if you have a chipped key maybe that is it, if you have a spare key try using that one, thats bout all my lil mind could think of.
Military Crew
MM Sapper Squad
Zombie Killing Club Member #4
Black Stang Crew Member #5
Old June 18th, 2009, 08:58 AM   #16
Molitor's Avatar
2004 Mustang Mach 1
Just talked with a guy in the smoking area, said that if you hit a bump or something rattles your car a lil the fuel shut off switch could kick on and it cuts all fuel flow and the car won’t even turn over, he said it’s a safety feature for if you ever get in an accident, he works at an auto shop back in the states. So have you hit any really big pot holes are any brick walls latly?
Military Crew
MM Sapper Squad
Old June 18th, 2009, 09:04 AM   #17
Drtbkercr5's Avatar
Just looking...
Drtbkercr5 will become famous soon enough
Had this happen to me in a ford probe while racing. DIdnt even hit anyone. THe switch is in the trunk on the left hand side in my GT so Im guessing it will be right around there in the cobra. Would not hurt to try pushing the button cuz even if that isnt the problem then the button wont change anything so its worth a shot
1997 Mustang GT SOLD
2004 Pontiac GTO SOLD
Torrid Red with Red Leather Interior
1 of 571 made.
Originally Posted by Drgnracin72 View Post
ive seen 2 boys fucking and ive seen roll racing, and roll racing is definitely gayer
Old June 18th, 2009, 09:15 AM   #18
Molitor's Avatar
2004 Mustang Mach 1
mhmm, would that be my Ford Probe?
Military Crew
MM Sapper Squad
Old June 18th, 2009, 08:28 PM   #19
Drtbkercr5's Avatar
Just looking...
nope. it was the red one that you stole the heater knobs out of you asshole!! I needed them when I was out on the dirt track
1 of 571 made.
Old June 18th, 2009, 11:26 PM   #20
Bearer of Bad News
Fluffy The Rhino's Avatar
I has mustang and legacy.
Slower than my Ruger.
Fluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to behold
I just ordered a new IAC for mine. It's been doing it for a few years. I've been lazy : D I just got used to gear braking
~MOD NUTSWINGER~
My Tongue Soothes Razorburn
STOPSAYINGFAIL.COM
EVERY FART IS A GAMBLE
Just Think Of Me As A White Blood Cell.
Threads Similar to: Any ideas?
need some ideas.. 32vGT 4V / SVT 9 March 9th, 2009 08:20 AM
any other ideas??? Traidmarx 5.0 Mustangs 32 March 4th, 2009 03:38 PM
ideas Rcyote Visual 14 September 27th, 2008 12:15 AM
Need some ideas 1Clean6 V6 Mustangs 12 September 2nd, 2008 06:02 PM
Any ideas? 2006GTARPD3 2005 - 2010 22 February 24th, 2008 03:33 AM
