LinkBack (1) | Thread Tools |
#41 |
Well you'll need a firewall adjuster with an aftermarket quadrant. The stock quadrant is self adjusting. I don't believe it's a problem with the firewall adjuster though.
So does the cable itself have an adjusting nut? or is it non-adjustable like a stock cable? |
#42 |
its adjustable
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 |
#43 |
the biggest thing i have is that the pedal is soft and the fork is moving a good 2in? this has never happend when i adjust it
#44 | |
Authorized Vendor
![]() 1993 Mustang GT
+1 The stock quadrant is self-adjusting. You must have either a firewall adjuster or an adjustable cable to use a aftermarket solid quadrant. I've tested a ton of clutch cable/quadrant setups. The best setup I found hands down is what I am running now and that is a Ford OEM Non-Adjustable Cable (Your Stock Cable or Maximum Motorsports Cable), a Maximum Motorsports Single Hook Quadrant, and any firewall adjuster with a set screw or click lock mechanism.
![]() AMNick Ex-Forums Liaison AmericanMuscle.com PM AMStanger - AM's New Forums Liaison with all questions and discount inquiries! |
#45 |
the only thing is that the pedel is so light and the fork moves, i though they were heavy clutchs and made the pedal hard?
#46 |
Mine definately takes more effort than a stock clutch.
My old stage 2 felt ridiculously heavy, but that's because it was a garbage set-up in there originally with the aftermarket stuff that it had when I bought the car. Once I changed over to a different quadrant, firewall adjuster and stock cable, the stage 3 felt easier than my stage 2 (pressure-wise). By adjusting the firewall piece, can you get it to engage at all? Either all the way out or in? |
#47 |
so how do i kow if the pressure plate is bad?
#48 |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/126222-flywheel-clutch-help-pics-inside.html
| need help pics inside - SVTPerformance | This thread | Pingback | June 23rd, 2009 04:52 PM | |
Threads Similar to: flywheel and clutch help (pics inside)
| Clutch flywheel help | svtkidd23 | 99-04 | 17 | March 18th, 2009 04:26 PM |
| Out with the old...in with the new clutch(pics inside)(videos coming soon) | WilltheThrill | The Clubhouse | 18 | February 11th, 2009 12:37 PM |
| 'Welded clutch to flywheel' pics | chad05gt | 2005 - 2010 | 12 | February 10th, 2009 11:07 PM |
| Clutch / Flywheel | sgrcltpunk | 99-04 | 17 | April 1st, 2008 01:27 PM |
| New Clutch w/ Flywheel ??? | Montanasvt | 4V / SVT | 8 | January 25th, 2008 01:12 AM |
