Discussing Popping/Looseness in Front End While Cruising in the 4V / SVT Forum. Also consider getting under the front end and checking all the steering components for play.... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 | |
More Than 7, Less Than 8
2007 Mustang GT
282 rwhp/292 rwtq
![]() JAKE'S PIITB CREW MEMBER#1 LACEY'S TIOTB CREW #1 BLACK STANG CREW #2
#22 |
17 inch cobra r's 245/45/17's checked for play yesterday and there was none. checked torque on lugs yesteday too. was fine.
#23 |
yeah i was under there yesterday and everything seemed normal.
#24 |
im thinking trying to figure out what kind of front end problem would cause a feeling through the gas pedal.
#25 |
im thinking its the suspension because the problem is vehicle speed sensitive..... when im on the freeway, even on smooth road, the suspension is constantly adjusting to the roadway so the suspension is moving up and down rapidly. in town the problem is slower because i am driving slower therefore the suspension is moving up and down slower
#26 |
Devil's Advocate
'98 Cobra/'90 GT 'vert
So, if you keep the speed the same, and put it in 4th, it still does it?
War is Peace || Freedom is Slavery || Ignorance is Strength Founder of the DMC |
#27 |
yes.
#28 |
Devil's Advocate
hrm... 91 octane... are you in Cali?
I'm still thinking that you need to seafoam the car. B-ports need to have it done, as one of the intake ports is dry and builds up carbon; seafoam is the only way to clean it without disassembling the head.
#29 |
when i hit bumps on the road though, the suspension seems fine, it doesnt affect the problem... it seems like something in the front lower of the car is lose or something and is rattling/popping. and gets more rapid with increase in speed
#30 |
yeah Cali... the car seems to have all the power it should though... ???
#31 |
i checked sway bar end links and they were tight. should i check sway bar bushings ?
#32 |
im very mechanically inclined but this problem is really hard to diagnose...
#33 |
could the exhaust be hitting something somewhere and causing the noise? because the faster i go the faster it would hit ? ?
#34 |
would the resonate through the gas pedal ?
#35 |
*that
#36 |
2007 MUSTANG
Slower than a F-16
You mention that even when you shifted to 4th it still did it. Can you duplicate the noise in lets say 2nd lower rpm (2000ish) on a smooth road. Heard and felt more on the smoother roads? Just curious. Is it a pop.pop.pop......pop.pop.....pop.pop? Just trying to get an idea.
![]() MUSIC BREAKS THE SILENCE |
#37 |
I think that i would be able to feel it still say if my foot was on the floorboard
#38 |
2007 MUSTANG
Slower than a F-16
But noticed more on smooth roads?
#39 |
yeah u got it ... random popping. if i am going slow, no matter what gear, as long as the car is quiet enough to where i can hear it, i hear it. and feel it. in town it'll be like pop.....pop..pop.......pop....pop on the highway itll be more rapid but still seems random.
#40 |
yes because its easier to distinguish. instead of hearing the suspension reacting to the road, i just hear the problem
Threads Similar to: Popping/Looseness in Front End While Cruising
| Back end sitting lower than front end? | Blown 97 GT | 96-98 | 31 | October 21st, 2009 04:45 PM |
| my front end | justinsstang | Suspension | 7 | February 8th, 2008 12:30 PM |
| New Front End - Like? | Gunny | 2005+ | 10 | November 19th, 2007 10:07 PM |
| Popping noise in the front lower area? | lighterzen | 94-95 | 3 | October 18th, 2007 01:41 AM |
| Popping In Front End When I Put In Drive Or Reverse | droppedbass87 | Suspension | 6 | November 3rd, 2006 03:52 PM |
