Popping/Looseness in Front End While Cruising - Page 4
Old June 12th, 2009, 12:58 AM   #61
1rnkpny's Avatar
2007 G9 Eye Catcher
1rnkpny has a spectacular aura about1rnkpny has a spectacular aura about1rnkpny has a spectacular aura about
An alignment wouldn't correct this issue. The only way to eliminate the noise is to replace the struts.
Old June 12th, 2009, 01:01 AM   #62
97CobraNow is on a distinguished road
so you think strut replacement ? does this typically happen to mustang struts? or could it be cause the car is lowered ?
Old June 12th, 2009, 01:02 AM   #63
motorcraft for $90 or monroe sensatrac for $60 ?
Old June 12th, 2009, 01:03 AM   #64
1rnkpny's Avatar
2007 G9 Eye Catcher
Lowering the car in a sense makes it worse. Hold old are your struts now?
Old June 12th, 2009, 01:04 AM   #65
i just bought this car on monday... they seem original equipment
Old June 12th, 2009, 01:06 AM   #66
1rnkpny's Avatar
2007 G9 Eye Catcher
Because your car is lowered with sportlines I would go with a strut that is made for use with lowered cars. Motorcraft and Monroe are meant for stock applications and have different jounce and rebound specs. An aftermarket strut for lowering springs would improve your ride quality as well. I bet it's kinda bouncy now? Hey?
Old June 12th, 2009, 01:09 AM   #67
its not really that bad actually... if i hit a bump though you'll feel it .. not like its bottoming out but a hard but cushioned bounce
Old June 12th, 2009, 01:09 AM   #68
it rides way better than i expected when he told me it was lowered and i have been in lowered mustangs and yes it was very bouncy...
Old June 12th, 2009, 01:10 AM   #69
*they were bouncy
Old June 12th, 2009, 01:11 AM   #70
what struts for the front and shocks for the back do you recommend ?
Old June 12th, 2009, 01:12 AM   #71
1rnkpny's Avatar
2007 G9 Eye Catcher
Your car is 12 yrs old with OE struts. I'd say replace them with a proper strut now. At the same time replace your rear shocks, they're probably OE as well. Go with a Bilstein or similar.
Old June 12th, 2009, 01:14 AM   #72
okay if i replace them and the problem is still there ... any ideas just in case ?
Old June 12th, 2009, 01:14 AM   #73
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Ugh, neither!
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old June 12th, 2009, 01:15 AM   #74
1rnkpny's Avatar
2007 G9 Eye Catcher
You take a look around, give me your Yr, make, model and I'll see what I come up with. Whether it be FRPP's or Eibach's. Something will work.
Old June 12th, 2009, 01:17 AM   #75
1rnkpny's Avatar
2007 G9 Eye Catcher
Everytime I've heard of this noise with your symptoms (pop.pop.pop...pop.pop) 98% has been the struts. It is hard to fully diagnose an issue over the web though.
Old June 12th, 2009, 01:18 AM   #76
1997 Mustang Cobra ... i found bilsteins on summitracing for 209 each ! ouch ! they are "heavy duty"
Old June 12th, 2009, 01:19 AM   #77
yeah... well thats good to hear that its 98% most likely the struts lol
Old June 12th, 2009, 01:19 AM   #78
+1
O o
\_\
Old June 12th, 2009, 01:20 AM   #79
1rnkpny's Avatar
2007 G9 Eye Catcher
Look around some more. You may find something cheaper elsewhere. I'll search the web as well to see what I find.
Old June 12th, 2009, 01:23 AM   #80
thanks i appreciate it... i have one more quick question that i dont mean to get you in depth on .... if my transmission seems too noisy/clunky could i be low on fluid or need a fluid change ? i dont mean to change the thread just figured i would ask you cuz you seem very knowledgeable... i g2g for a min but ill be back to check up. thanks for your help
Threads Similar to: Popping/Looseness in Front End While Cruising
Back end sitting lower than front end? Blown 97 GT 96-98 31 October 21st, 2009 04:45 PM
my front end justinsstang General Tech 7 February 8th, 2008 12:30 PM
New Front End - Like? Gunny 2005 - 2010 10 November 19th, 2007 10:07 PM
Popping noise in the front lower area? lighterzen 94-95 3 October 18th, 2007 01:41 AM
Popping In Front End When I Put In Drive Or Reverse droppedbass87 General Tech 6 November 3rd, 2006 03:52 PM
