Discussing Popping/Looseness in Front End While Cruising in the 4V / SVT Forum. redline dexron III auto fluid ?...
Old June 12th, 2009, 01:24 AM   #81
Old June 12th, 2009, 01:24 AM   #82
1rnkpny's Avatar
2007 MUSTANG
Slower than a F-16
Auto or manual? We can resume this 2moroow. Later.
MUSIC BREAKS THE SILENCE
Old June 12th, 2009, 01:29 AM   #83
Devil's Advocate
ReverendDexter's Avatar
'98 Cobra/'90 GT 'vert
All Cobras are manual.
Check Redline's site, I'm pretty sure they have a specific recomendation for the T45, though I don't know what it is off the top of my head.
I'm sure Royal Purple has an appropriate ATF as well.
And for the uninitiated, yes, the T45 runs ATF.
War is Peace || Freedom is Slavery || Ignorance is Strength
Founder of the DMC
Old June 14th, 2009, 04:26 AM   #84
1rnkpny's Avatar
2007 MUSTANG
Slower than a F-16
Have you found anything yet 97COBRANOW?
Old June 17th, 2009, 08:33 PM   #85
I found an Eiback Kit that comes with shocks and struts thats made to go with the sportline springs. so im thinking about that... and i got Redlines recommendations for fluids. so you think that popping noise is most likely the struts? its so annoying... it just sounds like somethings loose or something.. what about ball joints ??
Old June 17th, 2009, 09:52 PM   #86
1rnkpny's Avatar
2007 MUSTANG
Slower than a F-16
You wouldn't normally hear a ball joint noise on smoother roads. Besides you said you had the front end checked, correct? Do you have a longer screwdriver? 15" or so, or even a longer piece of steel kinda like threaded rod. Grab one of your buddies. Take the screwdriver or rod, hold it in your hand, place the other end of the screwdriver on the top of the strut shaft nut, place the end that is in your hand up against your ear and have your buddy jounce the front end up and down slightly like I mentioned before. Do you hear the popping sound through the rod (normally you should feel it too in the rod every so slight)?
Old June 17th, 2009, 09:54 PM   #87
1rnkpny's Avatar
2007 MUSTANG
Slower than a F-16
I wish I lived close cause I would cruise down and diagnose it for you.
Old June 18th, 2009, 01:40 AM   #88
im going to try that tomorrow. good idea !.... yeah ive had two people ride in the car with me and they cant hear or feel the popping.. i guess you have to be driving to feel/hear it ?
Old June 29th, 2009, 01:27 PM   #89
new sway bar bushings going in tomorrow. hope this solves the problem.
Old June 29th, 2009, 01:32 PM   #90
1rnkpny's Avatar
2007 MUSTANG
Slower than a F-16
Keep me posted.
Old June 29th, 2009, 08:08 PM   #91
'97'Cobra's Avatar
1997 Mustang Cobra
8.78@84mph
man everything yall are talking about is the same shit i have going on... i really dont want to invest in struts....
i usually wave first, but if the guy is sexy and i'm drunk, i might lift up my shirt and flash him as well.
Old June 29th, 2009, 08:16 PM   #92
'97'Cobra's Avatar
1997 Mustang Cobra
8.78@84mph
repost
Old June 29th, 2009, 09:46 PM   #93
1rnkpny's Avatar
2007 MUSTANG
Slower than a F-16
As was mentioned earlier in the thread, typically if the strut is slightly popping, it's not a big deal. Unless the strut has leaked right out or the popping is turning into a clunk (which would call for replacement) it's just really annoying and not an issue.
Old July 7th, 2009, 04:52 AM   #94
Sway bar mounting bushings were badly worn. im waiting on my new urethane bushings to see if this solves the problem. im also going to check the steering rack bushings. also read that it could be a motor mount ? anyone have any new ideas ? or new things i should check ?
Old July 7th, 2009, 10:19 AM   #95
1rnkpny's Avatar
2007 MUSTANG
Slower than a F-16
That wouldn't cause a suspension clunk. Engine mounts normally make noise under load not cruising.
Old July 7th, 2009, 08:15 PM   #96
'97'Cobra's Avatar
1997 Mustang Cobra
8.78@84mph
ya its def. not motor mounts, take the sway bar off too see if thats it.
Old July 12th, 2009, 12:25 PM   #97
1rnkpny's Avatar
2007 MUSTANG
Slower than a F-16
Soooooooo...........is the noise still there?
Update please.
Old July 13th, 2009, 07:00 PM   #98
I am getting new sway bar bushings, end link kit, and steering rack bushings. all polyurethane. we'll see what this does...
Old July 13th, 2009, 07:00 PM   #99
parts will be here today. hopefully i will have time to install them this evening its so damn hot here in cali.
Old July 13th, 2009, 11:42 PM   #100
1rnkpny's Avatar
2007 MUSTANG
Slower than a F-16
Hot weather? What the heck is that? It has been a monsoon here since july. Starting to hate the rain!
Threads Similar to: Popping/Looseness in Front End While Cruising
Back end sitting lower than front end? Blown 97 GT 96-98 31 October 21st, 2009 04:45 PM
my front end justinsstang Suspension 7 February 8th, 2008 12:30 PM
New Front End - Like? Gunny 2005+ 10 November 19th, 2007 10:07 PM
Popping noise in the front lower area? lighterzen 94-95 3 October 18th, 2007 01:41 AM
Popping In Front End When I Put In Drive Or Reverse droppedbass87 Suspension 6 November 3rd, 2006 03:52 PM
