Popping/Looseness in Front End While Cruising - Page 6
Old July 14th, 2009, 05:32 AM   #101
97CobraNow is on a distinguished road
lol it was over 100 degrees out today. I put in the sway bar bushings and end link kit. the car sits lower up front now. the end linkes are made for the car being lowered 1 3/4 in or more. the problem is still there however. it seemed to be unaffected.... I still need to put in the urethane steering rack bushings. the stock ones look okay though and i tightened them up. had no affect. i hate this problem.
Old July 16th, 2009, 01:44 AM   #102
Strut Mount ? on bumpy roads the strut is putting more pressure on the plate so it doesnt do the problem. on smooth road the strut is popping in/on the mount ? what do u think ?
Old July 16th, 2009, 03:06 AM   #103
1rnkpny's Avatar
2007 G9 Eye Catcher
1rnkpny has a spectacular aura about1rnkpny has a spectacular aura about1rnkpny has a spectacular aura about
If it was a mount, typically you would hear it more on rougher roads, because it is pounding it. And it would be louder. Rougher roads normally causes more violent piston movement in the strut and/or shock.
Old July 16th, 2009, 08:34 PM   #104
inner tie rods ? control arms ? trans mount ?
Old July 16th, 2009, 09:33 PM   #105
1rnkpny's Avatar
2007 G9 Eye Catcher
You said you had the front end checked, right?
Old July 18th, 2009, 03:50 PM   #106
I just checked the whole front suspension. everything was really tight. control arm bushings looked good. strut mount looked good. ball joints looked good. outter tie rods good. now, the inner tie rods, if i grab the tie rod with my hand, and try to jerk it, should it move ? I grabbed the driver side inner tie rod with my hand and i could jerk it back n forth.... looks like i need new motor mounts too... trans mount looked good.
Old July 19th, 2009, 06:02 PM   #107
1rnkpny's Avatar
2007 G9 Eye Catcher
When you wiggle the tire side to side, you'd be able to feel something is loose. To properly do it, it's a 2 man job. 1 to wiggle, and 1 to feel for looseness.
Old July 19th, 2009, 09:20 PM   #108
Ok so me and my dad went in the garage. i locked the steering wheel with the front end in the air. I had him wiggle at 12 oclock and 6 oclock to check ball joints, both sides were good. then i had him wiggle 3 oclock and 9 oclock. both sides would move in sync and you would here a clunking at the steering shaft. seemed normal. I then had him hold the steering wheel tight against the lock so it would no move, and i wiggled, what i felt seemed normal. both sides would barreellyyy move together, just the slack in the steering, like driveshaft slack "slap." i then went under the car while he was holding the steering wheel and grabbed the inner tie rods with my hands and jerked them around. the passenger side was solid, the driver side would pop and move in its socket slightly. I watched the outter tie rod ball joints and they looked good. but the driver side inner tie rod is definately not solid. I think replacing the inner tie rods will relieve my problem. what do you think ??
Old July 19th, 2009, 09:21 PM   #109
should i replace both outter tie rods when i replace both inners ?
Old July 19th, 2009, 09:42 PM   #110
HorsepoweR's Avatar
99 SVT Cobra
N/A Yet
HorsepoweR is on a distinguished road
Just a question, does it sound like metal clunking together for you?
Mods iN Garage.:.919 of 4040.:.Born on 3/29/99
F
ound
On
Road
Dominating
Old July 19th, 2009, 10:09 PM   #111
1rnkpny's Avatar
2007 G9 Eye Catcher
Personally, I don't think that is your noise. But if they are worn then replace them. Typically I don't replace the outers if they are tight when I replace inners (only if customer requested). But then that is your call. If you have the extra cash, get em, if not, don't. BTW don't buy the cheap stuff. They are cheap for a reason. Make sure you align it after. You may get it close, but even close can wear your tires down.
Old July 19th, 2009, 10:10 PM   #112
1rnkpny's Avatar
2007 G9 Eye Catcher
He was mentioning it to be a popping noise. pop.....pop....pop.pop........pop. On smooth roads. Doesn't hear it on bumpy ones.
Old July 20th, 2009, 02:49 PM   #113
they best way i can describe the sound is like a looseness like a ball joint loose in its socket
Old July 20th, 2009, 02:50 PM   #114
I think im goin to replace them and go from there. so hard to diagnose...
Old July 21st, 2009, 06:03 AM   #115
johnnyt03gt's Avatar
johnnyt03gt is on a distinguished road
i have rhe some problem it the top strut mount mine had a half inch of slack did the same shit i took it to a tire shop they hit it with an impact problem solved
cow lover, because without em their wouldn't be any hot fudge walnut brownie's covered with blue bell homemade vanilla ice cream, topped W/hershey's chocolate syrup and sprinkled nuts,
Old July 22nd, 2009, 02:20 AM   #116
oh really ? yeah i checked my strut mounts they were fine i hit them with my 450 ft/lb impact gun and they were tight. If the inner tie rods dont do the trick then it has to be something with the struts which is what 1rnkpny first suspected was the problem...
Old July 24th, 2009, 04:36 PM   #117
so i installed the new inner tie rods. the problem is still there like normal. its gotta be the strut or strut mount ? somethin to do with the strut ?
Old August 5th, 2009, 11:01 PM   #118
1rnkpny's Avatar
2007 G9 Eye Catcher
I've already stated what it would most likely be. So, let me know when the noise is gone.
Old August 9th, 2009, 09:12 PM   #119
I think your right. I only spent $100 dollars so far. So now its time for the expensive stuff. New struts, shocks, and cc plates. Eibach strut and shock kit made for my lowering springs or Bilstein HD ?
Old August 9th, 2009, 10:11 PM   #120
1rnkpny's Avatar
2007 G9 Eye Catcher
Eibach is a great product. Bilsteins are good, same as Tokico.
Threads Similar to: Popping/Looseness in Front End While Cruising
Back end sitting lower than front end? Blown 97 GT 96-98 31 October 21st, 2009 04:45 PM
my front end justinsstang General Tech 7 February 8th, 2008 12:30 PM
New Front End - Like? Gunny 2005 - 2010 10 November 19th, 2007 10:07 PM
Popping noise in the front lower area? lighterzen 94-95 3 October 18th, 2007 01:41 AM
Popping In Front End When I Put In Drive Or Reverse droppedbass87 General Tech 6 November 3rd, 2006 03:52 PM
