1998 Mustang GT
1:34.43@13.86
clutch compatibility question
will a clutch from a 96-98 cobra fit a 98GT? this guy says his clutch came from his "96-98 cobra and its a 10.4-inch, 10-spline clutch disc and pressure plate. (Stock size and stock spline number for 96 to 98 Cobras) I recently upgraded to an 11-inch 26-spline clutch when I replaced my T-45 transmission with a Tremec TKO 600."
is that a bunch of bs or is it true cause i thought they were all 10.5 inch discs. will this clutch from the cobra fit my 98 GT?
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
clutch kits for a gt's were all 10.5 from 89-00. the 96-98 gt's were 10.5 as well. 99-04 cobras were 11in set ups. all these same mustangs were same 10 spline input shafts as well. if you were running a 10 spline set up, the clutch would interchange.
Threads Similar to: clutch compatibility question
| clutch compatibility question | ndfrspd | 96-98 | 1 | June 14th, 2009 10:44 AM |
| X-pipe compatibility question | Jobra | 99-04 | 15 | March 3rd, 2009 07:55 PM |
| What is this value and compatibility? | INSTALLER020 | 5.0 Mustangs | 14 | September 13th, 2008 06:32 PM |
| Header compatibility | datsundave3 | 94-95 | 2 | July 21st, 2008 02:06 PM |
| S/C Compatibility... | G.T. Rags | 99-04 | 11 | December 15th, 2007 12:35 AM |
