Discussing Clutch Question in the 4V / SVT Forum. So i need to replace the throw out bearing in my 04 cobra. So i ...
Old June 18th, 2009, 12:48 AM   #1
burnout5.0's Avatar
2004 Mustang SVT Cobra
Clutch Question
So i need to replace the throw out bearing in my 04 cobra. So i need to know a good clutch for a street/strip kinda thing. and also any recommendations for anything else i should do while the tranny is out. Thanks guys.
Old June 18th, 2009, 03:04 AM   #2
Mustang RacR94's Avatar
03 mach 1
13.2@109
SPEC stage 2+ or 3 if your basically stock or basically not heavily heavily modified
Id get a stock OEM TOB from ford, the SPEC one's can be bad right out of the box, change the pilot bearing. besides that, if you want you can get a tranny output shaft seal, since you will be taking the drive shaft in and out it could get a tad worn, never had the problem but who knows
2003 Mach 1, 5 speed
"Dont worry ive locked horns with this fucker before"- TasteMyThunder
"More like my gameplay will break there will"-TasteMyThunder
www.myspace.com/mustangracr94
Old June 18th, 2009, 07:12 PM   #3
burnout5.0's Avatar
cool. thanks. any other opinions? trying to get a couple ideas.
Old June 21st, 2009, 02:40 AM   #4
burnout5.0's Avatar
no one else?
Old June 21st, 2009, 10:34 AM   #5
Air Embolism Assassin
Cricket's Avatar
2004 Cobra #2260/3768
I just recently had to replace my TOB, Clutch, and Flywheel.
Went with a stock replacement flywheel, Spec Stage 2+ Clutch, and Stock OEM TOB. I love the setup. Granted I'm still breaking it in, but once you get used to the clutch, it's great.
MM Cobra Club #18
Bubba is my hero
Old June 21st, 2009, 10:45 AM   #6
1999 cobra
+1 oem
my tob was bad after 1500 miles (spec)
1999 Mustang Gt
1997 eclipse gst(the faster one of the two)
MM Cobra Club #3
Old June 21st, 2009, 01:23 PM   #7
burnout5.0's Avatar
thanks guys
Old June 28th, 2009, 09:55 PM   #8
I can't believe nobody has said this...
Do the 26spline input shaft while you're there and be done with it.
Liberty Gears is what I went with, but I think someone else is making one too. D&D probably has one as well.
I used the Ram 98951HDT clutch (T designates the 26sp); basically a dual friction organic/sintered metal setup. Works really well all around and will take a healthy dose of track abuse too.
Otherwise a lot of guys run the Spec3+ clutch.
Old June 29th, 2009, 04:15 AM   #9
burnout5.0's Avatar
thanks man
Old July 1st, 2009, 02:28 AM   #10
BoostFiend's Avatar
'03 Cobra, '91 Notch
11.63@120.08, Cobra
Liberty 26 Spline input, Ford TOB, Lethal TOB sleeve, and resurface your stock flywheel. I twisted the crap out of my 10 spline input shaft with around 500whp. made it hard as hell to shift. I also used a Spec 3+ modified clutch by Pro-motion. It is pretty awesome so far. I can't wait to hit the track with it considering my best time so far is witha slipping clutch and a twisted input shaft.
Torch Red '03 Mustang SVT Cobra 10th Ann. Coupe
Oxford White '91 Mustang LX 5.0 Coupe
MM Cobra Club #36
Threads Similar to: Clutch Question
clutch question adrenaline=lifeline 99-04 3 May 13th, 2009 02:19 AM
Which clutch? + another question 2000stangGT 99-04 15 February 16th, 2008 10:45 AM
New Clutch question... Onemanzu V6 Mustangs 9 August 14th, 2007 09:26 PM
clutch question El_Cangri V6 Mustangs 9 May 3rd, 2007 09:53 PM
Clutch Question o3gtdgs 99-04 8 November 16th, 2006 12:50 PM
