#21 |
4V swapped '02 GT
(2v) 13.9@101
![]() ![]() ![]() ![]() iTrader: 10 reviews
i've been going over my tuning options and im kinda hung up at the moment. i took a look at the SCT Xcal3 and it seems that i could use this to tune my car with the 4v. i found a guy that did the swap in a 96 GT and it runs flawlessly with the stock GT tune on the PCM. i also took note that the Xcal3 works on all 96-08 mustangs (including cobra's and mach's) so couldnt i jsut buy that and tell the SCT rep what kind of cusatom tune im going to need when i place my order (it says you get 1 custom tune pre-loaded on it when they sell it to you) the Xcal3 is like 400 and a custom tune is about $500 or so depending where you go and to be honest there arent any good shops around me unless you drive 75+ miles one way to get there.
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 |
#22 |
1970 Mercury Cougar.
Yep, stock fuel pump and injectors. All is well.
1970 Cougar. |
Threads Similar to: 4 valve swap
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| four valve swap | 1badpurple96 | 96-98 | 0 | June 17th, 2009 03:31 PM |
| 4 valve swap | lineumup88 | 4V / SVT | 16 | April 21st, 2008 11:25 PM |
| Egr Valve And Pcv Valve Delete? | Jeffery9508 | V6 Mustangs | 16 | January 28th, 2008 09:45 PM |
| 4 Valve Swap | Danstang | 99-04 | 5 | December 19th, 2007 10:04 PM |
