03 Cobra Skip Shift Delete
Ok, this question is positively for those who own this car...No know-it-all guesses please. I know that tuners do it, and I know there is even a cheap hook-up from Autozone that can do it...Obviously everyone who has an 03 Cobra knows what happens when you romp on 2nd just a little too hard and try to go to 3rd, computer says "no" and puts you in 4th. I know that theres gotta be a lot of power to be unlocked by getting rid of it, cause the blower would probably make 3rd gear even more awesome if I could get in it no matter how high I took 2nd...but is any bad side to doing this? My friend has a 02 WS6 stroker thats been tuned and as you know its got the same tranny, same problem until the tune took it out but thats also a much more powerfull, naturally aspirated motor. Somebody enlighten me on getting rid of skip-shift in the 03 Cobra so I dont wind up eating my gears.
to my knowledge i did not know the computer had any kind of shift block like what you are describing, i know there is a shift light on the dash but if you are having probs shifting at high rpms sounds to me like a clutch issue/ drivetrain.
Zoolander
04 Cobra #2260/3768 1/820
Yeah man thats your drivetrain.
I was having issues getting into gear in higher rpms or when I was getting on it. Now that I replaced the clutch, flywheel, and TOB...it's like butter...warm soft butter. Not cold hard as a rock butter. |
13.1@105
![]() ![]() iTrader: 6 reviews
You're thinking about f bods.
2009 Super-Stangs Fantasy Football League Champion
Thanks Brees! |
2003 SVT Cobra
![]() But yeah, +1. No skip-shift on a T-56. |
I've never had a problem going from 2nd to 3rd. I think you may be talking about something that has nothing to do with the tranny. If it's what I think you are talking about, it can be fixed with a tune.
2009 ROTY
no problems going from 2nd to 3rd under full power here. and nothing special has been done to allow it. i do it frequently.
2003 Mustang Cobra
I had a problem shifting from 2nd to 3rd on hard pulls originally, but an aftermarket short throw shifter fixed all my problems. If I don't get it into 3rd its cuz I CAN'T DRIVE L@L
But when I first got my car I did read on SVTP that this was a common problem w/ some 03/04s (2nd -> 3rd getting stuck). They suggested the short throw swap. I'd say it was money well spent. Quicker shifts too.
2003 Sonic Blue Mustang Cobra FOR SALE: http://www.moddedmustangs.com/forums...ml#post2730654 |
#10 | |
MM's Orangest
2004 Mach 1 Mustang
![]() 360HP / 345TQ N/A |
2009 ROTY
from what i understand the t-56 does have built in stops. atleast this is what i was told when i put my pro50 on...
2004 Mustang SVT Cobra
448whp/475wtq
yes when i did my MGW it also said the the T-56 DOES have built in shift stops.
No 03/4 Cobra had the Skip-shift strategy. That belonged to the 'Vettes and F-body cars. Ford did not do it.
The T-56 in the 03/4 Cobra DOES have internal shift rail stops. If you have a shifter that has stops, you can either set them correctly or remove them without fear, your choice. If you're having shifting issues, go ahead and get a firewall adjuster and billet clutch quadrant. The Fiore pieces are top notch (lethalperformance.com) Combine that with a Max. Motorsports pedal height adjuster to get the pedal down where it's supposed to be; ymmv, but if you drop the pedal height any some suggest running the Steeda quick release quad. If you're running an aftermarket clutch with no or 1/2 the marcel of stock, then you don't have to, but otherwise you'll probably need it. |
'03 Cobra, '89 +'91 Notch
11.63@120.08, Cobra
I was missing shifts with my '03 and it turned out my 10 spline input shaft was twisted. Havent' had the problems since I switched to a 26 spline and replaced my clutch.
Oh and as others have said there is no "skip shift" feature in the T-56 in the 03/04 Cobras.
Threads Similar to: 03 Cobra Skip Shift Delete
| a little skip @ low rpms | MIKE 04 GT | 99-04 | 6 | January 16th, 2009 04:59 PM |
| after my diag for my skip | cassimus | Modular Mustangs | 0 | July 18th, 2008 12:24 PM |
| Skip A Shift | WilltheThrill | 99-04 | 24 | December 15th, 2007 06:08 PM |
| chevy skip shift | cali 5.0 | 5.0 Mustangs | 5 | April 19th, 2007 01:06 AM |
