Discussing FPDM help in the 4V / SVT Forum. has anyone had any experience with an FPDM failing on them? Reason why i am ...
Old June 30th, 2009, 02:15 PM   #1
MM Electrical guru
wraitherlx's Avatar
'99 SVT Cobra
FPDM help
has anyone had any experience with an FPDM failing on them? Reason why i am asking is im having issues right now with, im thinking, my fuel system. after i got my car back together she was fine for about a week and then threw a P0356 code for "Ignition Coil F Primary Circuit Malfunction". So I checked all the coils for resistance and spark and all checked out. Checked the line for continuity from the coils to the PCM and it checked out. So i cleared the code and it ran fine for about 10 minutes so it started to stumble and my WB would gradually lean out from 14.6. So I checked all my injectors to make sure they were plugged, changed out my fuel filter, and everything checks out. Fuel pressure at idle is at a steady 30psi. Cleared the code and let it run and same symptoms but now I got 2 codes; P0356 and P1233. P1233 states that "Fuel system disabled or offline". it also mentions something about my FPDM that it might be malfunctioning. I made sure that the inertia switch was plugged back in, which it was, but now im stumped. Any help would be greatly appreciated.
MM Cobra Club Founder
Benjamin Franklin - "He who sacrifices freedom for security deserves neither."
Old June 30th, 2009, 09:57 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83
stock pump? what power level you at?
right now, she is a jackstand warrior
if the car was a horse, i would shoot it!!!
project warhorse under construction almost done
Old June 30th, 2009, 11:12 PM   #3
MM Electrical guru
wraitherlx's Avatar
'99 SVT Cobra
yeah stock pumps, really not sure about power as ive yet to get it dynoed but the mods are in the garage if that will help you out at all.
Old July 1st, 2009, 09:54 PM   #4
MM Electrical guru
wraitherlx's Avatar
'99 SVT Cobra
Got it figured out. The P0356 was the main code that kept coming up. I did a continuity test again just to make sure from each B+ wire of each coil and then checked at the ECU. Just kept moving one probe back until I hit a spot that did not make an audible noise on my meter. Turned out that the #6 coil had a break somewhere. I traced the wire and found the spot. The wire had broken down internally inside the insulation but was still somewhat touching each other. when the car is idling it was fine but when i got on it I guess the wires would pull apart and then throw the code.
Old July 1st, 2009, 10:35 PM   #5
mm's nitrous mod
2000 mustang gt
11.79@115.83
glad you got it figured out.
Old July 1st, 2009, 11:44 PM   #6
MM Electrical guru
wraitherlx's Avatar
'99 SVT Cobra
thanks bro
Threads Similar to: FPDM help
Question regarding Cobra FPDM vs. Mach 1 Reloaded 4V / SVT 12 June 5th, 2009 11:36 AM
fpdm SWEET2KSTANG 99-04 27 May 8th, 2009 08:50 PM
fpdm/fuel pump wiring upgrade SWEET2KSTANG 99-04 8 February 11th, 2009 04:43 PM
FS: Zone 5 Stage 2 FPDM CobraStang161 Air/Fuel 0 February 10th, 2009 05:51 PM
Fpdm? itschristorres8 D'Agostino Racing Inc. 1 September 8th, 2008 11:47 AM
