03/04 Cobra SuperCharger
I've decided to get a supercharger and found one at a decent price. I'll be leaving shortly, for the 90 min. drive, to go look at and possibly buy. I was just curious as to what I should look for when inspecting it. Any words of wisdom is appreciated.
5.0L Cast Iron block/Forged internals-Melling Oil Pump w/Billet Gears-BBK Twin 65mm Throttle Body-BBK Longtube Headers-BBK O/R "x" Pipe- Maganflow Cats-B&M Sport Short Throw-Eibach Drag-Launch Springs-And Some More...Hope to run new set-up soon. Last edited by Techniq; July 11th, 2009 at 12:53 PM. |
I hope you aren't looking at just the supercharger itself off of a Cobra and hoping to bolt it onto the Mach 1 engine. There's a shitload of other parts you'll need as well...
+1^ yep
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 |
Just the Blower. Picked it up for $400.
5.0L Cast Iron block/Forged internals-Melling Oil Pump w/Billet Gears-BBK Twin 65mm Throttle Body-BBK Longtube Headers-BBK O/R "x" Pipe- Maganflow Cats-B&M Sport Short Throw-Eibach Drag-Launch Springs-And Some More...Hope to run new set-up soon. |
N/A 4v Guru
2003 Mach 1
So how are you going to put it on the mach motor? its not just a bolt up project and the manifold you need ,if you can find one, is freakin expensive. It is the single most expensive part if you try to buy it from ford. Just an FYI
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
u just went into a long hard and confusin voyage, good luck
may god be with u
It's Understood now. Obviously jumped the gun. Rookie mistake and something ill learn by.
yep if u plan on keepin it svtperformance and/or corral has some kit to convert it about 2-3k maybe a little bit more
1992 Lx
11.39@119.24
Yeahhhh huge list o parts needed, read up on it see if you dont wana just sell the supercharger
ill find it
posted on svtperformance by 99riocobra
i will first start off by saying please use that brilliant thing they came up with a while back called the "search" function. please! with that said, here's a list with some part numbers, and then the list i made on my own that's more "generic" but sometimes easier to interpret.... 1.) 2R3Z-6312-BAA Crank pulley /Harmonic Balancer 2.) 2R3Z-6C254-BC Supercharger Crank drive pulley 3.) 2R3Z-8678-BA Pulley w/mount Replaces stk alt. Pulley 4.) 2R3Z-8B603-BB Pulley bridge assembly for S.C. 5.) 1L2Z-8678-AB Idler pulley,timing cover LH side 6.) 2R3Z-6D080-BC Timing cover 7.) 2R3Z-6020-AA Timing cover gasket LH side 8.) 2R3Z-6020-BA Timing cover gasket middle 9.) 2R3Z-6020-CA Timing cover gasket RH side 10.) 2R3Z-10A313-AB Upper alternator bracket 11.) 2R3Z-10153-BA Lower alternator bracket 12.) 1U2Z-14S411-TA Electrical connector (alt. to harmness ) 13.) 2R3Z-6B209-AA Tensioner on timing cover 14.) 2R3Z-8260-AB Radiator hose 15.) 2R3Z-8A593-AB Radiator hose 16.) 2R3Z-8K576-AA Radiator hose 17.) 2R3Z-8286-AB Water cross over pipe 18.) F8ZZ-6881-AA Cobra oil cooler adapter Note: Use your stock gasket from your adapter or a leak will occur with a Cobra gasket! 19.) 2R3Z-6A642-AA Cobra Oil cooler 20. 2R3Z-9002-AA Cobra fuel tank 21.) 2R3Z-9H307-AB Cobra fuel pump 22.) 2R3Z-6F066-AA Eaton supercharger & inlet / T.B. 23.) 2R3Z-9424-BB Lower intake 24.) 2R3Z-6K775-BA Garrett factory intercooler 25.) 2R3Z-9H486-?? Intercooler to S.C. gasket 26.) 2R3Z-9A758-AA Cobra throttle cable 27.) 3U2Z-14S411-JUA IAT sensor connector 28.) 2R3Z-9H308A-?? Intercooler pipe to heat Exchanger 29.) 2R3Z-6K683A-?? “……………………………………..” 30.) 2R3Z-6K683B-?? “…………………………………….” 31.) 2R3Z-6K683C-?? “…………………………………….” 32.) 2R3Z-6K683D-?? “…………………………………….” 33.) 2R3Z-6K683E-?? “…………………………………….” 34.) 2R3Z-6K683F-?? “…………………………………….” 35.) 2R3Z-6K683G-?? “…………………………………….” 36.) 2R3Z-8501-AA Ford / Bosche water pump for intercooler 37.) 2R3Z-9L440-?? Factory heat exchanger 38.) 2R3Z-8A193-?? Heat exchanger mounting bracket 39.) 2R3Z-6C693-?? 2each bracket clamps 40.) 2R3Z-9H308C --?? Lower manifold to intercooler water adapter 41.) 2R3Z-6F089-?? EGR Valve 42.) 2R3Z- -?? EGR Tube to exhaust manifold 43.) 2R3Z- 8N500-?? Water pump intercooler bracket *** #29-35 are intercooler lines My List: 1) all intercooler lines and elbows 2) intercooler fluid reservoir 3) heat exchanger and mounting brackets 4) intercooler 5) intercooler pump and mounting bracket 6) intercooler cap(mounts to front of lower intake and has 1 in and 1 out intercooler line) 7) intercooler pump wire pigtail 8) timing cover 9) every single pulley except AC and water pump 10) supercharger pulley bridge that a few idlers mount to 11) both belts 12) lower intake 13) IAC valve(that thing that sits on top of the plenum/elbow) 14) supercharger and plenum 15) alternator and both mounting brackets 16) alternator wire pigtail 17) throttle and cruise cables 18) throttle/cruise cable bracket that mounts on the blower 19) the whole vacuum assembly and the stuff it all plugs into on the driver side of the blower 20) main feed line coming out of PS reservoir(the bigger one going to the pump) 21) return PS line(the other smaller one out of the reservoir) as well as the sections that "T" to right next to the radiator and to the booster 22) pcv valve and hose 23) EGR valve 24) EGR tube 25) oil cooler 26) all of the soft radiator hoses: a) upper hose going from the crossover tube to the radiator b) the big long one going from the middle of the crossover directly down and goes into the thermostat c) lower hose going from lower radiator to t-stat(about 10" long) d) hose going from oil cooler to t-stat(about 10" long also) e) smaller diameter hose going from bottom of coolant resevoir to t-stat ----> the last hose (e) may not be needed to swap, but i did anyway 27) coolant crossover tube(hard U-shaped tube going from head to head) 28) fuel rails(i'm not sure if the pressure sensor on the driver side rail is the same, but we swapped that too) 29) boost bypass valve actuator(circular thing with on the rear driver side of the blower) 30) gaskets: a) intercooler cap(mounts on front of lower intake) b) plenum to blower(if you get a supercharger with the plenum on already, then you don't need this) c) throttle body to plenum d) IAC valve to plenum e) EGR valve to back of blower f) timing cover(3 parts to this gasket, and they are all sold separately) g) supercharger to lower intake(this one can be reused if you can het the original from the guy with the 03) h) you can also use your original lower intake to head gaskets. you just have to cut off two small tabs(one on each one). you'll see when you try to line them up with the 03/04 lower intake. no big deal at all, takes 3 seconds. -----> you'll also need to do something for fuel. stock 03/04 injectors are fine. you can run a BAP on your stock pump, or swap to the 03/04 tank and dual pump setup too...
Here you go. You have lots of reading to do.
Eaton Swap..... - 2003-04 Mach 1 Registry Owners Club If you have any specific questions, I'll try and help you out. I did the swap about a year ago. |
Thanks for the list. If your correct on the price I'll still go through with it. Heres a couple of pictures. (Camera Phone)
N/A 4v Guru
2003 Mach 1
If you are gonna go this route with the eaton then go ahead and drop a little more money on a port job on the blower while you have time and it is off the motor. It will be well worth it and give you the most power potential out of the eaton.
2001 GT
its worth it once its done I love mine
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,443 RWHP/ 386 TQ |
Safud: MM's Resident Hadji
^ thats a damn long air filter lmao
I've saw a couple of Machs with the swap and was amazed.But I don't mind spending the extra. After the summer I wasn't planning on keeping the stock block anyways. Which reminds me need to get a thread up for the build. Wouldn't want to make another "oh shit".
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
97GT & 97Snake & 00L
T.B.A
^busted, haha
![]() 97 Cobra & 00 Lightning Beauty & The Beast I rev next to hybrids so they can hear me kill the environment ![]() MM Cobra Club Member #77 MM Lightning Club Founder |
Threads Similar to: About to go look at an 03/04 Cobra SuperCharger
| 1996 cobra swap with 03 cobra heads and supercharger. | stan's96snake | 96-98 | 14 | October 30th, 2010 04:57 PM |
| 03 cobra supercharger | livinthedream | 99-04 | 17 | February 18th, 2009 12:08 PM |
| 03/04 Cobra Supercharger | ECUSVT31 | 4V / SVT | 27 | August 1st, 2008 04:37 PM |
| can a 03 cobra Supercharger be put on a 97 cobra? | 97Cobra | 96-98 | 2 | June 16th, 2006 09:51 PM |
