cobra electric vaccum pump to ditch PCV system
Ive been researching around on different methods to scavenge the oil vapors and pressure from the crankcase and ditch the PCV system and came across someone that was using a 96 cobra electric vacuum pump in conjunction with a catch can and I was intrigued by it. I was wondering if anyone has any experience with it with a N/A setup as ive seen that alot of people are using it for boosted applications, or even any experience at all.
Thanks in advance. if you are interested in it I can post up links later once I get back from work
![]() ![]() BUILD 2 IN PROGRESS |
I'm Ron Burgundy?
'01 Cobra Vert.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 16 reviews
Hmm...interesting...
![]() ![]() 2009 Infiniti G37S Coupe (the daily) 2006 Yamaha R6 50th Anniversary Edition (the other toy) |
Billy Weston
I have tossed the idea around a few times but haven't really done any research on it yet. From what I have gathered 4th gen camaros have an electric pump that will work great for it.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
#4 | |
ill supply the beer
![]() ![]() BUILD 2 IN PROGRESS Last edited by wraitherx; July 22nd, 2009 at 10:58 PM. |
Billy Weston
We can do that.... Even if it barely works it will help.
thats what i was thinking... as long as it pulls into the catch can, even if a little, it still has to be, by far, better then having hot oil/gas entering into your intake and manifold. Im thinking that it can work but I just havent seen anything for N/A setups. Ive read that people are using it but I dont know if they are using the same componets or what. I know that for boosted apps people are using a Hobbs switch set at like 2psi to start the motor up via relay and start sucking, but what should we do in a N/A setup? any thoughts?
Billy Weston
I don't see why it can't run the whole time. It would be nice if we could get it to actually apply a vacuum to the crankcase.
hmmm... sounds like we might be doing alot of tinkering around with this thing
You dont think that we can?
we can talk about this more here in about an hour... im leaving work now... finally
Billy Weston
well the best thing to do is to hit up a junk yard and grab 1 of every pump we can think of. They shouldn't cost much. Then hook them up to some type of container with a bleeder and a vacuum gauge. Then choose the one that will pull the most vacuum.
Then all we have to do is hook it up. It may be a good idea to build an accumulator large enough to catch all of the oil. We can do that with used AC parts. In the end there should be less parasitic loss because of the lack of pressure in the crankcase. Also the motor should be less prone to detonation. Burning oil, even vapor will cause detonation.
#11 | |
Thats what I kept on thinking everytime i ran the set up through my head. I cant see it hurting at all. That sounds good to me. we can make a day of it. Ive got a buddy that works at U Wrench It but we can troll others as well. We can get the parts, come back to my place (or yours), and get at it. Sounds like new project in the works here. Here is what ive found so far and for those that are interested. this guy has it on his Tbird 331 Johns331's 1986 Ford Thunderbird on CarDomain - Page 3 One additional oil return from t The Pros and Cons of Racing Vacuum Pumps I think im also gonna get her dynoed before and after to see if there are any HP gains and im gonna log her to see if there is a difference noticed anywhere.
![]() ![]() BUILD 2 IN PROGRESS Last edited by wraitherx; July 22nd, 2009 at 11:00 PM. |
from what it looks like in the fourth picture is that the guy has the Valve covers directly going into the pump and then the pump (im guessing output) feeding into the enclosed catch can (accumalator)
or.... the valve covers T'd off into the 1 of 2 ports in catch can (im sure its baffled), catch can to inlet on pump, then outlet going back into intake
![]() ![]() BUILD 2 IN PROGRESS Last edited by wraitherx; July 22nd, 2009 at 10:18 PM. |
Billy Weston
seems like the best one to go with came on the 96-98 cobras. F6ZE-9A486-DC
yeah, thats what the concensus seems to be. Im sure that we can find some over at Johnson's and I think that JP knows someone that works there.
I tried pulling up that part number and came up with nothing. But i did find it at Rockauto. Id much rather get a used one for cheap to test until we can get the system finalized so that we dont ruin a brand new pump.
sounds good to me. Whatever they can do. So when do you guys want to get together and tackle this thing?
Billy Weston
I'm not sure, I'm slammed with sidework right now and am going to DC next weekend.
well, im pretty much in the same boat as well. Im usually free on weekends so the next time you get a free weekend and feel up to it just let me know.
did you guys ever do anything with this idea? im interested in possibly doin the same thing to the termi? also if it worked how about a how-to?
Termi swap,6spd,Spec 3 clutch,Steigmeir stage 3 ported blower,Big Moroso heat exchanger,ported heads,Sean Hyland CAMS,Billetflow 2.76 pulley,JLT power pipe,injectors,rails,full Magnaflow exhaust,Longtubes. |
Threads Similar to: cobra electric vaccum pump to ditch PCV system
| Electric Water Pump... | REIGNYC | 5.0 Mustangs | 12 | March 16th, 2009 06:28 AM |
| electric water pump... | Traidmarx | 5.0 Mustangs | 2 | January 29th, 2009 11:04 PM |
| Electric water pump | RX Bandit | 2005 - 2010 | 6 | November 6th, 2008 11:01 AM |
| Suggestions for an electric water pump or water pump motor. | N. Dave | 5.0 Mustangs | 4 | October 5th, 2008 08:49 PM |
| Electric Water Pump | MyBloodRunsBlue | 99-04 | 16 | January 27th, 2007 08:10 PM |
