Stock cam compatibility
Old July 25th, 2009, 12:14 AM   #1
tbird88tbo's Avatar
1998 Mustang Base Model
tbird88tbo is on a distinguished road
Hi everyone, I have a simple question. I am building a v block. I have the stock 98 heads and cams, but i am using 03 cobra heads and they came with the stock cams. I will be running a vortech v2 si trim on it at about 10psi of boost. I know that after market cams would make the most power, and i do plan on getting a set in the future, but for now i just want to know if i should run the 03 cams or the 98 cams. Also, for that matter, will the 98 cams even fit in the 03 heads? I dont want to take the cams off the 03 heads just to find out the 98 cams wont fit.
Old July 25th, 2009, 01:01 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
all the 4v cams will interchange. the 96-98 cobra cams are a little more aggressive than the 99+, i would suggest going with them. the 99+ intake manifolds are different, you will need the matching manifold for the c-heads as well.
Old July 25th, 2009, 04:31 PM   #3
tbird88tbo's Avatar
thanks, already have the manifold install...now i will have to take the cam and timing covers back off to do a swap
Threads Similar to: Stock cam compatibility
Which cam for a stock GT 01KnightRiderGT 99-04 9 June 12th, 2009 02:52 PM
stock cam qwik48r 2005 - 2010 8 November 6th, 2008 12:14 PM
Cam for a mostly stock 5.0 ? blakehunter316 5.0 Mustangs 40 May 24th, 2008 03:54 PM
Stock Cam cali 5.0 Modular Mustangs 1 November 7th, 2006 02:00 PM
