2004 SVT Cobra
Any idea what this is? Found in clutch.
I changed out my X pipe to the stock H today because one of the cats is bad. I had bumped the little tin cover that covers up the clutch fork so I removed it to straighten it back out. There was a little chunk of stuff bouncing around in there, so I guess I had more than one rattle. Looks like a pin or dowel of some sort, about 3/4" long and 1/4" diameter. It's a little mangled up now.
Here's what I found inside:
04 SVT Cobra MM Cobra Club Member #40 |
Resident DJ
'01 Cobra Vert.
2007 G9 Eye Catcher
Kinda looks like a dowl for the pressure plate.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
^+1
I.D.G.A.F.
Dowel pins are known for breaking off. In the 12v Cummins engine they call them killer dowel pins.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
2007 G9 Eye Catcher
But if it's 3/4 inch long like mentioned, that is typically normal dowel pin length, which I guess if that's what it is, either way you should hang onto it for when you do your clutch next. Or pull your inspection cover and check it yourself.
2004 SVT Cobra
Whatever it is, it doesn't look like either end is broken off. It's pretty mangled though, probably from getting chucked around inside the clutch. I'll know for sure someday though when I pull the tranny out to do my TOB that's chirping a little bit once in a while.
2003 Ford Mustang Cobra
Your car is falling apart Edward.
03 slowbra Polished Magnaflows Dr. Gas O/R X-pipe MM Cobra Club Member #39 |
2004 SVT Cobra
Not anymore. All fixed and no more rattles.
Threads Similar to: Any idea what this is? Found in clutch.
| Good idea or bad idea?? | flamed 98 gt | 5.0 Mustangs | 22 | April 17th, 2009 01:03 PM |
| Found a Computer to replace my Cobra - Good idea or bad one? | The Novice | 5.0 Mustangs | 8 | October 25th, 2008 12:24 PM |
| good idea or bad idea? | B0B | 99-04 | 6 | May 17th, 2007 11:18 PM |
| good idea or bad idea? | B0B | 99-04 | 2 | May 17th, 2007 01:57 PM |
| good idea??? bad idea??? | mustang1072 | V6 Mustangs | 19 | January 25th, 2007 12:33 AM |
