Anyone messed around with megasquirt EFI?
Old July 27th, 2009, 11:07 AM   #1
scp616's Avatar
scp616 is on a distinguished road
I'm about to build a centrifugal supercharged 4 valve taken to a 5 liter as soon as i sell this damned corvette. I ran all the specs through my engine analyzer and it says it's peak hp will be 775 with a peak torque of 632 ft lbs
Needless to say I'm going to be in need of some serious fuel at peak boost and since megasquirt utilizes a wide-band o2 sensor to achieve the proper AFR and a map sensor to measure boost to adjust ignition timing, it seems like the most advanced system i could possibly use and DEFINITELY the cheapest! However, currently it'll only work (at least the best for my application) with ford's EDIS ignition system as the coil-on-plug sequencer is still in the prototype stages and also is going to cost quite a bit more =P
It would be great if someone had used megasquirt before or if anyone foresees any problems with the EDIS ignition
Thanks,
Scott
02 GT --> long tube headers w/ x pipe and flow masters, throttle body w/ intake plenum, cold air intake, short throw, 255 nitto 555's all around, 373 diff gears, 2 inch lowering kit w/caster camber plates, sony radio working with stock system
Old July 27th, 2009, 09:17 PM   #2
Bearer of Bad News
Fluffy The Rhino's Avatar
I has mustang and legacy.
Slower than my Ruger.
Fluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to behold
Megasquirt? Sounds like a Ron Jeremy automotive product.
~MOD NUTSWINGER~
My Tongue Soothes Razorburn
STOPSAYINGFAIL.COM
EVERY FART IS A GAMBLE
Just Think Of Me As A White Blood Cell.
Old July 27th, 2009, 09:48 PM   #3
treblruh's Avatar
New 99 SVT Cobra Vert!
Dunno
treblruh is on a distinguished road
Send a message via AIM to treblruh Send a message via MSN to treblruh Send a message via Yahoo to treblruh
lol^
Go Pokes!
MM Cobra Club #33
VERT CREW #02
Old July 27th, 2009, 11:36 PM   #4
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
I don't hear about many Mustang owners using it, but from what I've heard it is a very good and user friendly tuning system.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old July 27th, 2009, 11:50 PM   #5
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I'd try asking either on the GRM boards or the official megasquirt boards. That last one has the advantage of having the two guys that originally made it as members.
O o
/¯/______________________
\_\
Old July 28th, 2009, 09:48 AM   #6
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
Thanks,
Scott
You could use a wasted spark coil pack, but it's possible to make an EDIS module drive the COPs - and it's been done on 4.6s making the same power level you are, too. We've got an article on how that's done here:
How to MegaSquirt your Ford Mustang
Old July 28th, 2009, 10:38 PM   #7
scp616's Avatar
I appreciate all the help ya'll
I've been all over that DIY site and hadn't seen the section on the 5.0, thanks for pointing it out.
I'm more of the mechanical type than the computer type so i've been a little confused as to what questions to ask on the megasquirt site, still doing my research so i don't look like a dumbass haha
Old July 28th, 2009, 10:46 PM   #8
scp616's Avatar
"You could use a wasted spark coil pack, but it's possible to make an EDIS module drive the COPs - and it's been done on 4.6s making the same power level you are, too. We've got an article on how that's done here:"
Thanks again, that article answered a TON of questions including that i will still have to keep the stock computer
I think i'll investigate using th EDIS to drive COPs, but it said i would be drawing double the voltage from the power supply (i still do not fully understand why that is...) so i may end up running coil packs and plug wires
Old July 29th, 2009, 09:47 AM   #9
Authorized Vendor
It fires the coils a little differently from the stock firing scheme. We haven't really seen any problems come from this, just wanted to make people aware of it.
The EEC-IVs can control a huge number of things. The dash on later Mustangs is pretty much entirely computer driven instead of reading straight from sensors.
Old August 25th, 2009, 01:37 PM   #10
scp616's Avatar
Will sharing sensors between the factory ecu and the megasquirt cause incorrect readings? Since sensors work by variable voltage, won't two different leads decrease the signal strength and cause things to act weird?
Old August 25th, 2009, 05:26 PM   #11
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
Typically you will want to make each ecu work on specific things and not share them.
If you go onto the megasquirt site I know there is a specific page on how to set up the megasquirt along side with the stock ecu.
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old August 31st, 2009, 09:29 AM   #12
Mustang RacR94's Avatar
99 cobra
N/A
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
isnt it just a shitty universal standalone type of deal, dont use it. just use SCT for now and save up for something along the lines of FAST or AEM standalone if thats the way you want to go. AEM is my personal favorite to use and I like using there tuning software the most.
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Old August 31st, 2009, 12:47 PM   #13
scp616's Avatar
It's a lot more sophisticated than most after market computers, the main reason i want to use it is because it uses a wide-band 02 sensor, so there's no chance of my engine running lean
Threads Similar to: Anyone messed around with megasquirt EFI?
The Megasquirt for Mustangs guide Matt Cramer DIYAutoTune.com 1 October 1st, 2009 04:15 PM
Megasquirt packages for Mustangs Matt Cramer DIYAutoTune.com 0 January 21st, 2009 09:35 AM
Megasquirt For 88 5.0 Mustang ridebmxfbm DIYAutoTune.com 2 January 19th, 2009 11:24 PM
Looking For Megasquirt? TurboLX 2.3 Mustangs 5 December 2nd, 2007 08:07 PM
