96 cobra nosie
Old July 28th, 2009, 10:39 PM   #1
1996 Mustang Cobra
96whitesvtcobra is on a distinguished road
96 cobra nosie
Ok, sorry to have to ask for help again but once again I got a weird noise. A little back ground i just changed the clutch,TOB,pilot bearing and flywheel. It has a spec stage 2 clutch used the OEM TOB and pilot bearing. The tranny was rebulit about 6 months ago. It ran great no noises or anything i have put about 600 miles on it since the clutch change. About 60 miles ago i started getting this high pitch whine/sceraching i thought it was a brake low pad sensor due to the fact that it would and when I hit the brake but it was coming from the tranny area so tonight to make sure I put it in the air and started checking over everything it is diffently coming from under the car. So I checked everything out made sure it was full on fluid and it was made sure the rear end was full and it is checked all bolts and they are all tight. It makes no diffrence if your in gear or not or if you have the clutch pedel in. I can shut the car off and let it roll down hill and it still makes the nosie. It sounds like a door on a old house opening but just constant does not change with speed. I did notice today when i hit a bump it stoped for a about a block. Any direction on were to look next?
Old July 28th, 2009, 10:42 PM   #2
1992 Lx
11.39@119.24
make sure your brake lines arent touching the tires and parking brake cables not touching the driveshaft
Old July 28th, 2009, 11:05 PM   #3
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about
its sounds like the pilot bearing, if its a high pitched skweek that would be my first guess. Did you grease everything up when you put it back in? Sometimes the little bearing on the Pilot Bearing get dry if you dont oil them up good. I had that problem not to long ago.
i usually wave first, but if the guy is sexy and i'm drunk, i might lift up my shirt and flash him as well.
MM Cobra Club Member #61
Old July 28th, 2009, 11:11 PM   #4
1996 Mustang Cobra
I greased everything really good. I used a ford racing bearing. Would the piolot bearing still be moving with the car in netural engine off just rolling? Would I hurt anything if I jacked it up and pulled the drive shaft off and let it idle in first to see if it still makes the nosie to determine if it is something in the tranny or not? Not sure if this is a good idea or not.
Old July 29th, 2009, 01:57 AM   #5
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
i dont see why it would hurt it
Old July 29th, 2009, 02:33 AM   #6
1996 Mustang Cobra
So I think it is fixed. I jacked it up and ran it just idling 15 mph is what the speedo said. It was differently coming from the tail shaft off the transmission. So I pulled the drive shaft ran it did not hear it. So I put some wheel bearing grease on the yoak of the drive shaft when i pushed it into the rubber it looked like most the grease came off but drove it around for 15 minutes and did not hear the noise and before it was instant it might stop for a second if you hit the brakes but it would start back up. I did not drive it on the highway but drove it around town and got up to 40 so I'm hoping it stays gone.
Old July 29th, 2009, 02:42 AM   #7
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
sweet man hope that was it
Old July 29th, 2009, 03:31 AM   #8
1996 Mustang Cobra
Just went out and drove it again and it still seems to be gone. Figure's crossed.
Old July 29th, 2009, 03:32 AM   #9
1996 Mustang Cobra
Oh and thank you all for your help. I know I ask a lot of question's but I'm still learning. I really appreciate the responses.
Old July 29th, 2009, 06:46 AM   #10
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
shit man nobody here minds anwsering questions....
Old July 29th, 2009, 10:53 AM   #11
97 Cobra
acidtonic will become famous soon enoughacidtonic will become famous soon enough
Keep those figure's crossed man. Hopefully you got it.
Converted to the Dark Side.
06 Apex Silver Evolution IX GSR
- Turboback Exhaust, Tune
- Wideband O2, Trustz backlight gauges, Apexi turbo timer
- Stock wing, but soon to be wingless.
- Guessing 280-310 at the wheels.
02 Red Escape V6 4x4
Threads Similar to: 96 cobra nosie
nosie from top end jayrock Modular Mustangs 2 September 2nd, 2008 06:27 PM
Squealing Nosie hardhitter 99-04 11 December 15th, 2007 10:47 PM
