01 Cobra surges until WOT...sometimes.
Old August 26th, 2009, 04:59 PM   #1
MDK210's Avatar
2001 SVT Cobra
MDK210 is on a distinguished road
I have a 01 Cobra, built motor, procharger P1SC, SVT focus pump, KB BAP, blah, blah blah. I bought the vehicle maybe a month or so ago and everything seemed good even the owner ran it hard while I was in it. She runs strong 98% of the time but one day I hit WOT, shifted into into 3rd and stomped my foot back on the gas pedal, she surged like it wasn't getting fuel, I let of the throttle a bit and then it ran normal. Today I was riding with another member from here and I was cruising in 2nd, then tried WOT, it surged for a second and then took off. I was so confused I didn't look at my fuel pressure gauge to see if it was a pressure issue. It doesn't do it all the time but I rarely hit WOT because of the streets in the area. Cobra has a boat load of mods so I'm not sure what I should reference in this thread to help figure it out but feel free to ask. It was tuned by Jon Lund before I bought it and will be getting retuned by Mike Rousch at Mid Atlantic Performance Sept 12th, originally for a timing bump but now I want him to investigate this. Thanks for any info.
2008 F150 5.4l Roushcharged: http://s330.photobucket.com/albums/l...0F150%20Roush/
2001 SVT Cobra 4.6l Procharged: http://s330.photobucket.com/albums/l...20SVT%20Cobra/
Old August 26th, 2009, 09:13 PM   #2
Bearer of Bad News
Fluffy The Rhino's Avatar
I has mustang and legacy.
Slower than my Ruger.
Fluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to beholdFluffy The Rhino is a splendid one to behold
Possibly bad gas? Old fuel filter? Always check the simple, cheap shite first : D
~MOD NUTSWINGER~
My Tongue Soothes Razorburn
STOPSAYINGFAIL.COM
EVERY FART IS A GAMBLE
Just Think Of Me As A White Blood Cell.
Old August 26th, 2009, 09:14 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
you got a W/B? If so what is your reading when this happens?
BUILD 2 IN PROGRESS
Old August 26th, 2009, 09:23 PM   #4
MDK210's Avatar
2001 SVT Cobra
The couple of times it's happened the gas has been different but respectable gas stations such as Shell and BP are used. They do use 10% ethanol in the area so it runs a little rich. Might do the fuel filter, miles are super low (24K) so it may have not been done. I do have a W/B put since I never know when its going to happen my reaction time is slow and then I try to look at my fuel gauge but then I remember the W/B and I just miss both in the process, lol, so much shit going on! I know this is almost impossible to troubleshoot but I just need ideas. Will start with filter.
Old August 26th, 2009, 09:37 PM   #5
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
yeah bro if you have someone with you have them watch your wideband so that you can see what is going on. Mine did that for a little bit then i changed out my plugs and fuel filter and got a new tune and nothing happens now. also what are your plugs gapped at and have they been changed? But yeah change out the fuel filter and check your plugs as they can indicate whats going on if you know how to read them
BUILD 2 IN PROGRESS
Old August 27th, 2009, 10:13 AM   #6
phoenix99's Avatar
phoenix99 is on a distinguished road
look at your plugs
i had this problem with my car and i replaced 2 plugs and it run fins !
Addicted to adrenaline
Forged 5.4 4v with B heads and nitrous. Tuned by me
Old August 27th, 2009, 10:16 PM   #7
MDK210's Avatar
2001 SVT Cobra
thanks for all the info guys, I'll do the fuel filter but I need to double check the plugs, I'm not sure what's in there now to be honest or what I should use but I know what they should look like physically. I'm about to score a 8-rib belt setup from BGG and a re-tune Sept 12th so I'm hoping that between the filter replacement, plug check, 8-rib install and a re-tune that the issue goes away. We will see.
Old August 28th, 2009, 05:59 PM   #8
phoenix99's Avatar
dont forget to add some di-electric grease to your spark plug boot when you reinstall them.
good luck !
Old September 6th, 2009, 11:06 PM   #9
MDK210's Avatar
2001 SVT Cobra
finally got around to installing the fuel filter and changed the oil as well which did appear to be a little low after pumping the old stuff out. I just took her for a little drive to go get some gas and I THINK the little hesitation is gone. I don't want to jinx it but there's not really a road to open her up on to test it so for now there's no issue. Fingers crossed!
Old September 16th, 2009, 09:14 PM   #10
MDK210's Avatar
2001 SVT Cobra
spark plugs installed and didn't work. I think I have a super lead! Talked to my soon to be new tuner and he immediately mentioned this! I think this is the golden ticket!
Kenne Bell 99-04 Mustang Fuel Rail Pressure Disc [FRPDISC] - $15.99 : Performance Parts - Ford Mustang - Cobra - Dodge Viper - Chevy Corvette - C6 - LS1
Old September 17th, 2009, 12:12 AM   #11
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
who are you getting it tuned by? hopefully they can figure it out
BUILD 2 IN PROGRESS
Old September 17th, 2009, 03:14 AM   #12
Molitor's Avatar
2004 Mustang Mach 1
1994 Dodge Ram 5.9L 4WD 1976 Monte Carlo
Molitor has a spectacular aura aboutMolitor has a spectacular aura aboutMolitor has a spectacular aura about
hope that works! like Fluffy said, check the cheap shit first. its most times something small, like when that space ship crashed awahile back it was like a 15 cent peice that failed lol, yay tax dollars, sorry got off subject alittle
Military Crew
MM Sapper Squad
Zombie Killing Club Member #4
Black Stang Crew Member #5
Old September 17th, 2009, 10:03 AM   #13
MDK210's Avatar
2001 SVT Cobra
Mike Rousch at Mid Atlantic Performance in Richmond.
Old September 17th, 2009, 11:51 AM   #14
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
let me know how the tune turns out
BUILD 2 IN PROGRESS
Old September 17th, 2009, 01:11 PM   #15
MDK210's Avatar
2001 SVT Cobra
will do
Old September 17th, 2009, 08:51 PM   #16
1rnkpny's Avatar
2007 G9 Eye Catcher
1rnkpny has a spectacular aura about1rnkpny has a spectacular aura about1rnkpny has a spectacular aura about
Ethanol causes havoc on fuel injection. You could have gummed up injectors.
Old September 17th, 2009, 10:15 PM   #17
MDK210's Avatar
2001 SVT Cobra
ethanol is almost in ever gas station across America these days. Shell and BP are for starters. Injectors only have 4K miles on them anyway. Ethanol just means you have to tune richer to balance it out. My 08 F150 only has a ethanol tune not to mention it's only 10% at most. I'll keep that in mind as a expensive fix.
Old September 18th, 2009, 02:07 AM   #18
1rnkpny's Avatar
2007 G9 Eye Catcher
You obviously haven't seen what ethanol can do to injectors and fuel pumps. Can cause all sorts of driveability issues. Of course that from the fuel companies that use higher amounts of ethanol in their fuel.
Old September 18th, 2009, 03:09 AM   #19
Renegaderacer's Avatar
2003 mustang gt
12.18 @113.22 mph
Renegaderacer will become famous soon enough
not being a dick but cars dont suffer from the same issues as they use to from ethanol because most gas has it they design them to take it i run it in mine and race mine all the time runs like a charm! All my cars do and have, mabe you've just bought alot of bad gas.....
vortech sq, 3.73 gears, steeda rear lower control arms, j&m upper rear control arms, h&r race springs, mgw short throw, pype o/r x pipe, magnapacks cat back, vortech after cooler, 3.33 pulley vortech mini race bypass valve 410 rwhp 390 rwtq
Old September 18th, 2009, 12:06 PM   #20
Trick Tuners's Avatar
KB'd GT
It sounds like the returnless fuel system hesitation issue. There were a bunch of good threads on modfords in the terminator section. It can be tuned out most of the time. Adding the KB disk will help, as well as removing the pprv. If you can datalog, log the FRPS and see if you get a massive FP spike on "let off", and a dip when you get on it. You can test it by going wot, full let off in gear, and then punch it.
Fuel Pressure and the FRPS - Trick Tuners Forums
The PPRV - Trick Tuners Forums
Threads Similar to: 01 Cobra surges until WOT...sometimes.
Surges 94blakonblak 94-95 10 June 26th, 2009 10:21 PM
20 ft. Storm Surges... Dansby The Clubhouse 56 September 13th, 2008 09:09 PM
99 stang surges when put in gear, or with ac on dobermean 99-04 7 August 16th, 2007 07:30 PM
My 96 Cobra Runs like a Powerstroke at WOT High RPM Ryan Paymaster Modular Mustangs 9 June 25th, 2007 03:29 PM
Engine surges at start and idle fluctuates 200KMILES V6 Mustangs 2 May 3rd, 2006 06:23 PM
