98 4.6 motor apart: CAM keyway
Old September 9th, 2009, 06:21 PM   #1
Cobra Chris 98 is on a distinguished road
Hi all,
I'm building my 4.6 out of my 98 cobra and I just started the timing. I was putting the secondary sprockets back on (right head) and the keyway block came loose and fell out. I'm not sure if it snapped or if it is supposed to be jammed in there. If it's not supposed to be like this then it looks like I might have to pick up a high lift cam kit ( Blue Oval Chips Inc. - Product » 4V High Lift Camshaft kit )
The pictures are:
1: keyway block
2: block placed back
3: block out
Thanks,
Chris
98 4.6 motor apart: CAM keyway-1.jpg   98 4.6 motor apart: CAM keyway-2.jpg   98 4.6 motor apart: CAM keyway-3.jpg
Old September 9th, 2009, 09:37 PM   #2
bitemark46 has a spectacular aura aboutbitemark46 has a spectacular aura about
The keyway block is supposed to be 1 piece that you can remove it. But if yours broke into multiple pieces and if you can buy a replacement block then do it. Its just like the keyway on a crank. However, if you have the cash get some cams.
-Mark
-Mark-
98' N/A Cobra (Stock longblock)
11.79 at 114.64 (1.62 60ft)
Old September 9th, 2009, 09:44 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
are the keys on the older cobras not part of the timing gear like on the later 4v's???
Old September 10th, 2009, 02:43 PM   #4
OK so it is supposed to be removable? I didn't want to use it if not. I want to order the high lift kit but my goal is to finish the timing and put her back in before my birthday (October). So I just need to think about it for a little and decide.
The keyway block I'm showing here is like a stopper for the key on the timing gear. The secondary sprockets doesn't have the keys so they can slide past the block.
Old September 11th, 2009, 07:29 PM   #5
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
the cheapest way (if you can do it ) is to remove the entire key and go to a machine shop and have new ones made. Very easy and cheap. Hell you can buy key stock at a good bolt and screw shop and just cut your own. You can upgrade cam gears to the newer style that has them built into the gear like sweet was asking about (what I would do)
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old September 11th, 2009, 08:16 PM   #6
Honeybadger is Crazy
futureMACH1racer's Avatar
2008 F-250 Super Duty
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
96-97 Ford Mustang Cobra 4.6L DOHC Timing Chain Kit New:eBay Motors (item 110428936659 end time Sep-26-09 22:24:51 PDT)
^ This is equivalent for IDK, but I wsih I could help you, so I'll go out on a whim, and post this up.
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Threads Similar to: 98 4.6 motor apart: CAM keyway
Cam Degree'ing off motor Dolbs4082 99-04 5 April 8th, 2009 04:36 AM
Cam installation - Comp cam stage II Dolbs4082 99-04 4 February 28th, 2009 11:36 PM
How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? Jonathan General Tech 3 January 2nd, 2008 10:34 PM
E cam or F cam horsepower and 1/4 mile time questions GreyGhost 5.0 Mustangs 1 August 21st, 2006 07:25 PM
