97 cobra sc losing oil pressure, help??
I have a 97 cobra with a V-1 vortech sc. just recently the engine started losing power and shutting off. the oil pressure will drop to zero. but here is where it really has me, the oil pressure gage will bounce around and then even out at normal but when it does the engine starts a slight knock on the passenger side, then it will drop back to zero and knocking will stop. from everything i know it seems that it should be the other way around...please help
sounds to me like a sparatic/faulty oil pump,does it get hotter temp wise while this is happening?
Termi swap,6spd,Spec 3 clutch,Steigmeir stage 3 ported blower,Big Moroso heat exchanger,ported heads,Sean Hyland CAMS,Billetflow 2.76 pulley,JLT power pipe,injectors,rails,full Magnaflow exhaust,Longtubes. |
did you ever figure it out?
no but going to replace the oil pump this weekend in hopes that does i t thanks
Threads Similar to: 97 cobra sc losing oil pressure, help??
| losing oil... | delgadog | 94-95 | 8 | August 3rd, 2009 05:02 PM |
| cobra running a 15.4, and losing to a honda....... | v606er | Videos | 19 | January 31st, 2009 08:04 PM |
| losing oil pressure | marks87gt | 5.0 Mustangs | 7 | July 14th, 2007 07:27 PM |
| oil pressure | hmotes | 5.0 Mustangs | 8 | January 18th, 2007 09:30 PM |
| oil pressure | turp | V6 Mustangs | 1 | August 19th, 2006 11:59 AM |
