![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
03 cobra shortblock....
This is the 03 cobra shortblock im going to snag.... Everything look aight to you guys? Recognize it as the forged cobra block?
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
my question is, this should be good to go after some good cleaning and such huh? Recommendations?
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
looks of from the pics you got there. i would spray the cylinders down with some lubricant, turn by hand, and to get a better look at what the cylinder walls look like.
N/A 4v Guru
2003 Mach 1
Yes after some good cleaning it should be fine. How many miles are on it? might be worth re ringing it since your in there and a quick hone on the cylinders if it had alot of miles. But it looks pretty good
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
I have an 03 Cobra Shortblock that shaved a rod bearing. 40K miles not run hard at all.
Let me know if you are interested current offer is 1100.00. Shawn 801-835-0333 |
1998 Mustang Base Model
I thought cobras all came with aluminum blocks. That block is clearly cast iron, look at all the rusty spots. Plus, the 4v blocks had bungs cast into the vally for knock sensors, and that block does not. I dont think that is a cobra block, and gt blocks didnt come with forged internals. Another thing to look at would be the bolt patern on the crank for the flywheel, a forged cobra crank will have 8 bolt holes, where as a non forged crank will only have 6.
2000 gt
03/04 cobras came with iron blocks tbird.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
tbird, that is more of the info i was looking for. he said while he was out of town his roommate sold it to someone else anyway so not an option anymore. Ive decided to do my own build anyway.
cool
#10 | |
97 Cobra
Yep and also dont forget to mention that there are 8 bolt cast cranks as well. Some GTs got an 8 bolt cast instead of the common 6 bolt cast.
Also the whole point of the cobra block is that it comes nearly done. If you are going to rebuild it then I'd HIGHLY recommend going with a used Teksid block instead. Teksid has 6 bolt mains compared to the Iron block having only 4. Teksid blocks are rated stock to handle 1600hp. Only problem is the weak internals. But if you are rebuilding the other block anyway then why not get a Teksid? Then you'll have a block just as strong and 90lbs+ lighter instead. my 2c.
Converted to the Dark Side. 06 Apex Silver Evolution IX GSR - Turboback Exhaust, Tune - Wideband O2, Trustz backlight gauges, Apexi turbo timer - Stock wing, but soon to be wingless. - Guessing 280-310 at the wheels. 02 Red Escape V6 4x4 |
#12 | |
Threads Similar to: 03 cobra shortblock....
| 03/04 cobra shortblock...2v heads... | BakerFX4 | 99-04 | 25 | September 21st, 2009 04:43 PM |
| '98 cobra shortblock | blkragtop | 99-04 | 2 | October 29th, 2008 04:59 PM |
| 01 cobra shortblock in my 96 GT | caintcatchmyGT | 96-98 | 4 | May 7th, 2008 08:56 PM |
| the best new shortblock?? | caintcatchmyGT | 96-98 | 7 | May 7th, 2008 03:00 PM |
