#21 |
2001 Cobra
Also when i pulled the air intake off you can look down the TB and there is alot of what looks like rust deposits in the intake. What causes this? Should i pull the intake and have it cleaned. I dont want to start putting on all my aftermarket parts untill my idle problems are gone.
#22 |
if you ordered a kenne bell and your gonna order cams,you better put a built shortblock on that list cuz with just the kenne bell your pushing the limits of that stock shortblock,remember the 99'-01' cobras have the 4 valve but no forged internals,also think about upgrading the rearend cuz those 28 spline shafts are gonna go pop with anymore than about 400hp or so and then you need to upgrade your........the list goes on and on and on..........sorry just tryin to help
Termi swap,6spd,Spec 3 clutch,Steigmeir stage 3 ported blower,Big Moroso heat exchanger,ported heads,Sean Hyland CAMS,Billetflow 2.76 pulley,JLT power pipe,injectors,rails,full Magnaflow exhaust,Longtubes. |
#23 |
2001 Cobra
i thought 01 cobras had 31 spline shafts
#24 |
nope 28 splines in the 99'-01' the termi's have the 31 splines.
#25 |
1998 mustang cobra
i was told you get big gains from custom grind cams, i was quoted 1600 not including install
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
#26 |
2001 Cobra
Ford Mustang SVT Cobra - Wikipedia, the free encyclopedia
this site says 2001 went to 31 spline. anyone taken the irs apart and checked? |
#27 | |
31 spline in termis only......
#28 |
2001 Cobra
Seams like there is alot of info on the cobra out there that contridicts, mosly likey your right. But alot of places are stating that early 01 cobra has 28 spline and the rest have 31 spline. This is even listed at Drive shaft shop. But never the less im gonna do the stage 5 half shafts so in the end parts still have to be swaped out for stronger stuff. So did you do the termi swap ur self? was it a huge project, problems...i keep thinking about it, but the non intercooled kenne bell seams so much easyer.
Threads Similar to: 2001 cobra help
| 2001 Cobra vs 1999 Cobra | airforcebjf | 4V / SVT | 30 | March 30th, 2011 08:24 AM |
| 2001 Cobra vs. 2003-4 Cobra | kstills | 99-04 | 24 | May 26th, 2008 08:10 PM |
| 2001 Cobra | Dansby | The Clubhouse | 27 | March 11th, 2008 12:19 PM |
| 2001 cobra s/c? | 01CobraRob | 99-04 | 24 | March 8th, 2008 02:37 AM |
| 2001 Cobra | 01LaserRedCobra | 99-04 | 3 | December 14th, 2007 04:31 AM |
