mixing up 4v motors? - Page 2
Old September 30th, 2009, 05:15 PM   #21
98Cobra_sleeper's Avatar
1998 mustang cobra
98Cobra_sleeper is on a distinguished road
Originally Posted by Boostang View Post
ooh... i so theres not a big difference between the 98 and 01 cobras?
well, the 98 cobra had the wonderful teksid blocks. the 01 cobras had the WAP block i believe, which was known for not being the strongest. the 01 cobras had 'c' heads, which are good for torque. the 'b" heads are great for high rpm hp.
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup)
comin soon...ON3 turbo kit, PTE7175
Old September 30th, 2009, 05:19 PM   #22
Boostang's Avatar
1997 Mustang GT
11.01@128.32
Boostang will become famous soon enough
Send a message via AIM to Boostang
hmmm. thats some good info as now im glad i have the b heads because im building this motor for high rpms
Old September 30th, 2009, 05:21 PM   #23
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
There is if you make it that way. Depending on your power goals and if you are going boost or not. If you just want a nice N/A motor then some forged pistons,I beam rods and a stock cast crank can be good for decent power. the little things are all the lower end bolts have to be replaced since they are torque to yield, gaskets, I would do valve seals since its apart, that can give you a nice little N/A motor on a decent budget. Add in some bolt on's like CAI, pullies, windage tray, and headers. You can make in the upper 300 range if not close to 400. I would go with forged flat tops if you are going N/A and punch the motor .020 over. get some FR500 cams or GT super car cams (they are a pretty cheap set for the budget minded and I'm running the GT's and I like em) You can spend a whole lot of money on a N/A 4v build or you can do it on a pretty light budget. Like I said just decide your target power and then you can move on.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old September 30th, 2009, 05:21 PM   #24
Boostang's Avatar
1997 Mustang GT
11.01@128.32
well the throttle cable and the coolant hoses are really the only little shit.. but if u get the whole motor be sure to get them.. cause those hoses new added together cost around 300
Old September 30th, 2009, 09:31 PM   #25
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
Well I have had a blower laying around all year, I'd like to throw it on, want to aim for a more serious chunk of power, so I have to do the bottom end, I just figured I'd make it a 4v while I'm at it. Right now I'm unsure of the best rout to take, a low mile mark8 motor with forged internals and c heads isn't looking like a bad option, though I question if it would just be cheaper to buy a block and go from there.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old September 30th, 2009, 10:54 PM   #26
Boostang's Avatar
1997 Mustang GT
11.01@128.32
i have some brand new 11cc bored .020 over manley pistons im putting in with some manley h beam rods and some nitrous.. what would be the best route to go with wat i have?
Old September 30th, 2009, 10:54 PM   #27
Boostang's Avatar
1997 Mustang GT
11.01@128.32
id go with the low mileage lincoln
Threads Similar to: mixing up 4v motors?
Mixing Nitrous parts? MyGT 99-04 1 September 29th, 2008 01:06 PM
octane mixing 07 STROKER 2005 - 2010 10 July 31st, 2008 09:37 AM
Mixing Oil hellbred07 2005 - 2010 7 July 11th, 2008 04:51 PM
mixing gas mu5t4ng 96-98 6 January 6th, 2007 12:34 AM
Mixing Rocker Ratios In One Motor Zak 5.0 Mustangs 2 October 26th, 2006 12:37 PM
