Please Help!!!!
OK i need some help badly and quickly!!!
i have an 01' cobra that has a full termi swap i am looking at putting some real power to the ground so i think its time for an sra swap i have a friend who has a fresh 8.8 with moser 33 splines,new posi unit,welded ends all the goodies. We have struck a deal for a swap now this is where my problems start.......Its out of a 90' GT so i know its atleast 1.5" shorter width wich i actually like cuz i can run a 11.5" wide wheel now without a problem but i have a few questions..... 1-is there any difference in the fox body rearend other than the width difference of 1.5" 2-with it being a fox body what do we do about the rear springs? i know he has to use lowered irs coils to bring the rear down but can i use the fox body coils? or get new? 3- can i just get the swap u-joints so i dont have to replace the pinion shaft? 4-i have seen the article on the irs swap into the fox coupe but would a fox GT be the same as the coupe? 5-CAN SOMEONE PLEASE HELP ME!!!!!!!!!! ![]() I have also posted this on SVTP,before someone tells me to go check there lol.
Termi swap,6spd,Spec 3 clutch,Steigmeir stage 3 ported blower,Big Moroso heat exchanger,ported heads,Sean Hyland CAMS,Billetflow 2.76 pulley,JLT power pipe,injectors,rails,full Magnaflow exhaust,Longtubes. |
no one at all? this is very disheartening!!!
Resident DJ
'01 Cobra Vert.
try SVTP
I love having you "speacial" kids around
,you keep everything so lively!!!
1998 mustang cobra
sorry man. perhaps calling a speed shop that works on cars like these would have the answer.
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
1- no
2- springs for a SRA will be needed. wether its a lowering springs, or a stocker. 3-yes 4- yes 5- hopefully i did
Assistant to the Manager
no
yes yes yes Prob not Maybe yes I'm not sure NO
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng |
