since everyone seems to be gettin cams.... - Page 2
Old October 4th, 2009, 09:43 PM   #21
98Cobra_sleeper's Avatar
1998 mustang cobra
98Cobra_sleeper is on a distinguished road
really? why? the car makes 912hp
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup)
comin soon...ON3 turbo kit, PTE7175
Old October 4th, 2009, 11:16 PM   #22
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
there is a breaking point on some of it as well. you have to remember the cams have to be matched to the motor. that is a 2v, has to spin quiet a bit of rpm, and needs all the duration it can get. the lsa might be a little on the tight side, but it may need it for "his application" as well. there is a lot to setting up a cam, especially for hardcore applications.
Old October 4th, 2009, 11:34 PM   #23
1998 mustang cobra
ok i get it i think. Thanks for the info!
Old October 4th, 2009, 11:36 PM   #24
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the 2v heads dont flow very well, so geting it right for aggressive set ups is critical. if he is pouring on a large volume of boost, he has to efficiently get it out of ther at high rpms. turbo's like cams that favor the exhaust flow naturally, but its getting the cam to time it right so that it balances the intake side out as well.
Old October 5th, 2009, 12:51 AM   #25
Aceman74 is on a distinguished road
The Ford GT cams are ok for a turbo car but more for a supercharged application. The best cam is a custom turbo cam that could actually gain you 65-100hp. Spend a little money you'll be happier in the long run. Also did you change out the valve springs?
Old October 5th, 2009, 01:12 AM   #26
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
depends on boost pressure and volume as well. he may not be pushing enough to utilize "cutom turbo cams". the gt cams will do very well with the turbo's.
Old October 5th, 2009, 09:02 AM   #27
1998 mustang cobra
well when i had my heads raceported i had the valves and springs replaced. I dont know what kind, it may be stock replacement stuff. it was stainless steel valves and springs. as fas as volume and boost pressure, i have 67mm turbos and an plannin on runnin maybe 12psi.
Old October 5th, 2009, 09:43 AM   #28
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the gt cams will be just fine. if you have the $$$ for different cams, then obviously go for a set of turbo grids (customs not a must).
Old October 5th, 2009, 10:03 AM   #29
1998 mustang cobra
ok sweet.
Old October 5th, 2009, 09:38 PM   #30
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Also the stock springs are actualy realy good. they will handle more than you think becaus you are not going to have a high high lift your dohc setup.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old October 6th, 2009, 04:49 PM   #31
1998 mustang cobra
wonderful. well, if i was to acquire a turbo grind set of cams, what brand do you reccommend?
Threads Similar to: since everyone seems to be gettin cams....
gettin an O/R X Willy Mo 99-04 10 November 25th, 2008 11:19 AM
Gettin Some Patriot Stage 3 Heads and Comp xe270ah cams!!! mustangmanic 99-04 44 November 18th, 2008 06:26 PM
im gettin me WilltheThrill The Clubhouse 4 October 31st, 2007 02:54 PM
