97 cobra sc and 97 4.6 MARK VIII 32 VALVE
whats the difference block wise with the 1997 4.6 MARK VIII 32 VALVE and the 1997 SVT cobra
Priest of the Car Gods
Blocks are the same (teskid), crank is forged in the cobra, cobra has different cams (at least, the intake cam is different), I think the lincoln head casting is slightly different, too.
97 Cobra
Heads have a single very minor difference with the Lincoln heads having a small raised area between the valves that shrouds them.
COPS on the lincoln instead of coil packs IMRCS are vacuum actuated on the lincoln intake is different and garbage on the lincoln Might be more but thats what I believe to be correct.
Converted to the Dark Side. 06 Apex Silver Evolution IX GSR - Turboback Exhaust, Tune - Wideband O2, Trustz backlight gauges, Apexi turbo timer - Stock wing, but soon to be wingless. - Guessing 280-310 at the wheels. 02 Red Escape V6 4x4 |
the lincoln crank os cast/cobra forged, pistons the same, head casting for both sides are the same, rods are different. and they use the same block. and the mark uses the 98 cobra style imrc's
97 Cobra
Genibus Nitito Canus
good to know
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, SLP Loudmouth ![]() |
Threads Similar to: 97 cobra sc and 97 4.6 MARK VIII 32 VALVE
| Will Lincoln Mark VIII block work on 1998 Cobra? | cobra98sd | 96-98 | 14 | December 27th, 2009 03:18 PM |
| Mark VIII help? | John's_stang | 99-04 | 10 | April 9th, 2009 02:30 AM |
| Difference between 98 cobra and Lincoln Mark VIII mod motor? | noyz25 | Modular Mustangs | 35 | October 18th, 2007 06:42 PM |
