#21 |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
i have the one's that were suppose to go into machboy's car. pm me if interested.
#22 |
1992 Lx
11.39@119.24
dude PSR up here, which is a very well know shop in the mach1 world, charges i think 27 hours to do cams
#23 |
mm's nitrous mod
2000 mustang gt
its quiet a bit of time. i hate even trying to get valve covers out with motor in car.
#24 |
2003 gt
5.4 32v on the way
Will the fr500 kit work well in a set of navigator heads? Is that a proper starting point for boost?
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
#25 |
mm's nitrous mod
2000 mustang gt
no. the fr500 cams are set up for N/A applications.
#26 |
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
How about the GT supercar cams? Are those N/A or boost cams?
Sweet, I PM'ed you about the cobra cams.
Do the Right Thing, Cook. ~Zip. |
#27 | |
Moderator
![]() ![]() BUILD 2 IN PROGRESS |
#28 |
Well I wouldn't do a 4v build, but there's a good reason for me to (atleast I've convinced myself it's a good reason). My car is a DD so I can't really yank the motor out of it and rebuild that one, so I'll rebuild another motor and swap it in. Since I'm building a separate motor, I went with the teksid block. That block happened to come in a complete Mark VIII w/ 4v B heads.
Unless I've severly underestimated costs I don't see how it's gonna be that much more to do a 4v over a 2v since I've already got basically all the stuff I need, and anything I'd have to buy for the 4v I'd probably have to buy for the 2v anyway since I don't have many mods. Someone correct me if I'm wrong on any of this stuff Bottom end: I think everything would be the same whether I went 2v or 4v Heads: I already have 4v B heads and the PI heads. Either way I'd port them and maybe have a valve job done. Probably cost a little more to do the 4v heads, but well worth the increase in flow Cams: 4v - swap in 96-98 cobra intake cams; 2v - hitech stage 2 cams Intake: 4v - swap in 96-98 cobra intake if I can. 2v - 75mm tb/plenum LT Headers: Pretty sure the price is the same either way Supercharger: 4v - 96-98 cobra mounting bracket for my Procharger; 2v - already have bracket. Might have to re-route some pipes/bends either way Other than that, I'm not sure what else I'd need that would make the 4v build more expensive
#29 |
Not sure what is hard to find. If you mean finding OEM parts then yeah I agree, but there is a wide aftermarket of parts since heads are the real difference. I mean 600.00 2v heads 1200.00 4v bump sticks. Double everything basically.
Threads Similar to: 4v cam options
| Cam installation - Comp cam stage II | Dolbs4082 | 99-04 | 4 | February 28th, 2009 10:36 PM |
| F/I options? | 101fng | 2005 - 2010 V6 | 6 | June 5th, 2008 11:10 AM |
| speed density cam options | itsmyfiveoh | 5.0 Mustangs | 4 | May 13th, 2007 05:01 PM |
| E cam or F cam horsepower and 1/4 mile time questions | GreyGhost | 5.0 Mustangs | 1 | August 21st, 2006 06:25 PM |
