LinkBack (1) | Thread Tools |
#21 | |
2008 Black Bullitt
Sylv Rivial :P
[/SIZE]Bullitt Crew #http://www.youtube.com/watch?v=jeYscnFpEyA rk_2000_Z/28:"Talk about tuck tail and run. Zoom Zoom motherfucker." |
#22 |
97 Cobra
The S197 may not be much heavier, but its very different and here's why.
The chassis is way heavier than people think. Ford did everything they could to hide the weight gain when switching from SN95. They already had bad press from the last few switches they did like 5.0 - 4.6npi (no power) and 4.6 B head to 4.6 C head (99 recalls) and they wanted to avoid the whole "This new car is a pig" mentality. So they covered it up. For instance they did a whole bunch of weight reduction mods to the S197 that the SN95s didnt have done yet. Like Aluminum blocks, 3 link rears, front coilovers, solid rears on the GT500, etc. They lightened other stuff and I cant remember off hand but other things were lightened almost across the board. For instance the wheel spindles got weaker from SN95. Griggs racing tested it and found it unusually weak for track use. But they said pre S197 cars were fine. So you could still remove a lot of weight from an SN95 while the S197 there is much less to do. For instance just swapping out the IRS widens that 255lbs gap to well over 300lbs from the 03 Cobra to the GT500. Despite all the power stock vs. stock the 03-04 Cobra is faster in a straight line. GT500 faster around the track (solid rear is way better for tracking). To get a good comparison you have to make things equal... SN95 with aluminum block, coilovers, solid rear, and 3 link easily weighs under 3300lbs. Now compare that against the S197 GT and you see about 300lbs more depending on options and such. (mid 3600's weight) Even if we're generous and say 100lbs of the 300lbs is new safety stuff like side air bags that *still* makes the new chassis 200lbs heavier. And with all the pound here, or 10 ounces there thinking Ford did to hide the weight of the S197 I bet it's heavier than that even. So say what you want but I dont think that kind of weight gain is worth the increased stiffness you hear about. I'd rather add way lighter subframe connectors and have a stiffer AND lighter car that doesnt need to make as power power to go as fast. Weight is way more important than power. Power only helps one thing while hurting mpg and driving up insurance rates. Weight loss helps everything. Braking, brake wear, straight line handling, cornering, launching, acceleration, traction, mpg, trailoring costs, suspension wear, etc. Yeah the GT500 engine is better I wont dispute that. I just wish it was lighter. Better yet place it inside of an SN95.... GT500 engine swap - Corral Forums
Converted to the Dark Side. 06 Apex Silver Evolution IX GSR - Turboback Exhaust, Tune - Wideband O2, Trustz backlight gauges, Apexi turbo timer - Stock wing, but soon to be wingless. - Guessing 280-310 at the wheels. 02 Red Escape V6 4x4 |
#23 |
Billy Weston
I have to find the video but there was a TT terminator in the 7's with the stock long block.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
#24 |
97 Cobra
Also the new 2011 info leaked and the GT500 will have an aluminum 5.4.
I want to hope this will be the dry-sump 5.4 block from the supercar but I dont know. They just found the ordering codes which show aluminum 5.4. I havent really researched it beyond that but I do think the 2010 GT500 in black is a sexy beast, especially from the sides. I didnt like the GT500s until the 2010s look. Now with aluminum blocks that can handle the power I will be finally thinking about one instead of building my 97 more.
#25 |
2003 Mustang Cobra
9.94@135
thanks bro!
Jake Silver '03 Cobra Coupe Auto - First 9 Sec Eaton Only car! 6.27@108 9.90@134 w/ a 1.35 - NO Nitrous! 6.01@113 9.50@139 w/ a 1.30 - Nitrous! **Click here for all my video's!!!**
#26 |
Priest of the Car Gods
Acid - only thing I disagree with is that lighter-weight cars have better traction. All else being equal, more weight on the tires = more grip. That's why race cars have all the aero bits - to increase their effective weight at speed, and thus get better traction.
#27 | |
9.74@142
No problem man! I hope to one day gat my car dialed in as good as yours!
Now when once it gets to the piont of having too nuch weight transfer (wasting the motion lifting the front of the car too high, instead of pushing it forward) to where suspension adjustments or limiters will be needed. A car too light can have traction issues too, but that is rarely a factor in a fairly heavy 94 to present mustang (and most fox's unless they are completely gutted with an lsx swap or a turbo 4) For a track car,I'll take a properly set up 94-04 over an s197 anyday.
#28 | |
Also, you're not separating weight in terms of mass to accelerate versus weight over the tires to increase grip. Drag times takes the net effect of both, and I'm sure the extra weight slows you down more than the added traction is worth. That doesn't mean that lighter weight gives you more traction, though.
#29 | |
97 Cobra
A heavier car will need more traction to make the same corner as a lighter car at the same speed. It doesn't actually increase traction, but rather decreases the load that traction has to accept which has the net effect of seemingly making traction better. I think I need one of those sig disclaimers like you have Reverend
#30 |
9.74@142
As you get to know me, you will realize I have a one track mind
#31 |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/141065-fastest-stock-long-block-03-04-cobra-motor.html
| Cal Poly Football Loses a Home Game For 2010 | College Beat … « What’s Popular? | This thread | Pingback | October 23rd, 2009 02:48 PM | |
Threads Similar to: Fastest stock long block 03\04 cobra motor
| stock long block record? | mystang0673 | 99-04 | 47 | July 14th, 2009 09:10 AM |
| fastest stock motor npi stangs | product1620 | 96-98 | 17 | June 2nd, 2008 07:53 AM |
| want to do a motor swap or new long block | thecloneranger | 99-04 | 4 | April 16th, 2007 03:25 PM |
| Stock Cobra Block and GT Block the same?? | bbrewer03 | 96-98 | 2 | August 26th, 2006 01:31 PM |
