#21 |
i'd start simple, fuel fliter, air filter, plugs
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#22 |
2004 Mustang Mach 1
1994 Dodge Ram 5.9L 4WD 1976 Monte Carlo
+1!^
![]() Military Crew MM Sapper Squad Zombie Killing Club Member #4 Black Stang Crew Member #5 |
#23 |
97 Cobra
You could just gut your car like I did to mine.
15-18mpg driving like an idiot, 25-29mpg city, 30-34mpg @ 1600rpm highway sustained. Long ass list of things taken *off* of the car. Enough to run 12.68 with a good tire on a stock motor from filter to exhaust tips. Cant wait until next summer when another good 100-150lbs will be removed. I do however have issues with balance right now being so front heavy. I want an IRS to smooth out the ride and correct my weight distribution. The car even with the stock suspension corners like mad just being so light. I can live with the sub par IRS and just have a nice riding car.
Converted to the Dark Side. 06 Apex Silver Evolution IX GSR - Turboback Exhaust, Tune - Wideband O2, Trustz backlight gauges, Apexi turbo timer - Stock wing, but soon to be wingless. - Guessing 280-310 at the wheels. 02 Red Escape V6 4x4 |
#24 |
i get about 15-16 mpg in the city, check your airfilters, or just do a tune up and see what happens
#25 |
2001 mustang cobra
unknown
buy some electronic parts cleaner and clean your mass air meter, chances are its dirty. First thing i did when i bought my 01 cobra a few months back was clean the mass air meter, clean the IAC, plugs, oil, filter and air filter. my car just rolled over 100K last night on my way home from work (i stopped on the highway and took a picture with my cellphone) this spring im changing every filter and fluid, tranny, rear, antifreeze. if im driving like a douchenozzle ill get 18-20 but for the most part i average 23-25. granted i live 3 miles froim the highway and i drive 90 miles every day. im happy as hell with that mileage too, my 01 ranger i traded in for this car got 18.............
MM Cobra Club Number 69 ![]() Courage is going after a whale in a rowboat and taking the tartar sauce with you........... Last edited by Mr.Soup; November 13th, 2009 at 11:52 AM. |
#26 |
You guys dont have shit on me. Lets see
1: My 02s are gone havent been able to replace them very bad makes ECU dump in fuel 2: My Tune was made in 58 degree weather and Iam using a sniper bad too 3: Because of tune my plugs are always full of fuel double bad 4: Dont have Wideband yet there for cant tune car my self. 5: Need cash for everthing I just mentioned and the Economy is fucked All this equalls to maybe and thats a big maybe 7mpg city 12mpg highway driving chill which is very hard almost impossible to do with a Cammed out fully built Cobra. Lets see if anybody cant be that and trust me I know it sounds like Iam happy about it IAM NOT
![]() Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne http://www.youtube.com/user/MysticCobra04 |
#27 |
Too Soon, Junior!
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
i'll trade you my 13 mpg bolt on GT for your 7 mpg cammed out fully built cobra
![]() 03 GT - Scrapes on lane markers - Modded 02 Cougar - Able to clear most speed bumps - Some mods 01 Explorer - Parking blocks NOM NOM NOM - Stock |
#28 |
LOL I might be mad but that doent mean Iam not going to get that fixed as soon as I get the money for everything. When I do Iam shooting for 25Mpg if Iam successful I will be glad to help everybody with tunning number but it will be a while since Iam poor right now.
#29 |
97 Cobra
Just watch out for all the fuel washing away your rings..... Or if enough gets into your oil, a bearing.
Someone I think on here said they had a car that was dumping crazy amounts of fuel and it ended up just exploding out the oil pan. I doubt thats remotely typical though. Cant remember if it was here or Corral. Also you probably know whats up, but if you are having drivability issues and its stuttering and reeking of fuel you could just have a bad or disconnected TPS. I believe that will throw a code. I almost lost my motor when a rodent of some kind got into my engine bay and chewed my TPS wire right at the connector so I couldnt splice it back. I was a few blocks from a Murrays luckily so I limped it there and scanned it. Car was popping and the exhaust smelled of oil, and the dipstick was loaded with fuel. Ended up trying to solder it back on in the parking lot but it was too windy. I ended up finding an alligator clip which I managed to clip the remaining wire to the amazingly small amount of wire left right at the connector. I literally went right across the street to get an oil change and engine flush, once again thankfully an Uncle Eds oil change place was exactly across the street from Murrays, then I drove very carefully a few miles to the nearest ford dealership that stocked the replacement connector and wire. I made it a couple miles with a freaking alligator clip holding a sliver of the TPS wire together. Put the new one on and she's been running good ever since with all kinds of rough driving. I think another block or two and that fuel would have washed out my bearings and probably my rings too. I got super lucky that time. Needless to say I left poison out for my little critter friend. Also put a small box where my battery goes in the engine bay since it was in the trunk. I only wish I could have found the bastard dead for the gratification. He cost me well over $200 for flush,oil change, replacement tps wire, soldering gun & solder, plus the hours of my life. Sorry for the long story but I figured someone would get some use.
#30 |
Atomized
damn that's crazy i get like 20 intown and 25 on the freeway with my fox with 3:73
spray and pray |
#31 |
Dude dont think I ever herd of that one what almost cause your motor to blow a fucking rat bro a rat. How that rat got into the engine bay is not that amazing cuz he could have crawled from underneath but the fact he went for the tps he knew what he was doing guarenteed he was from chevy lol.
#32 | |
*2003 Azure Blue Mach 1*
- Eibach Pro Kit lowering springs - Authentic Saleen wheels (18") - UPR o/r X-pipe - Borla Stinger catback - 5% tint - Sequential turn signals - 5sp w/ MGW short throw shifter - FRPP shifter knob MM Mach 1 Crew |
#33 |
well, an update. I had it serviced at the shop over thanksgiving break.
I drove from fargo to wisconsin, and blew over 80 bucks in fuel... I averaged 18(ish) highway. after servicing I did the same drive, 5 mph faster on the interstate and got 26(is). Spark plugs looked fine, replaced the air filter and fuel filter. the fuel filter was HORRIBLE and looked like it had never been changed. Air filter was looking normal. |
#34 | |
I just dont want to take a chance of me breaking it yet! Ive had the car for about a month.. wanted to get better knowing how to drive nice before I try to drive her hard! the last thing I need to do is break my new and only car... haha |
#35 | |
Yes + a billion and helo Sexyness. A hot blonde that drives a Mach1 why cant you live in Miami
#36 | |
#37 | |
ouch... well, college money is tight. I dont have the cash to drop on a new clutch if I burn this one out. Drive only as fast as you can afford doesnt ONLY imply to tickets. This summer, I plan on having some fun. Maybe even after xmas, well have to see. |
Threads Similar to: Gas milage? problem?
| Gas Milage | Rattltrunk | 2005 - 2010 | 31 | March 19th, 2009 01:54 PM |
| better gas milage | v606er | The Clubhouse | 45 | June 6th, 2008 07:13 PM |
| gas milage | mustang2517 | 99-04 | 63 | January 16th, 2008 09:03 PM |
| Gas Milage | acehogg69 | 2005 - 2010 | 11 | February 8th, 2007 02:06 AM |
| Gas Milage | Steamboat 16 | All Other Vehicles | 26 | January 31st, 2007 03:18 PM |
