2001 cobra
check engine light
The problem is my check engine light keeps coming on and the trouble codes it throws are
P1000 - OBD system P0305 - knock 1 if i remember right P0325 - knock 2 if I'm right P0330 - #5 misfire P0174 - system lean (sometimes) the car is a 2001 cobra with a DSS level 10 stroker motor with bigger throttle body, under drive pulleys, 4v heads, sct tuner. The question i can not figure out is why i keep getting knock 1 & 2 if the knock sensors are turned off with custom tune . I have checked plugs look fine. i have had a couple people say its the computer about ready to go or try running higher than93 octane gas. Did not have these problems until stroker was put in. Before had stock cobra motor with same mods and no issues. Any help would be great. thanks. Jason |
Threads Similar to: check engine light
| check engine light help!! | rewadferger | 96-98 | 7 | May 18th, 2009 05:49 PM |
| Check Engine Light...Again... | trueblue02GT | 99-04 | 10 | January 1st, 2009 11:12 PM |
| i cant get my check light engine off | XPLICITSTANG | 99-04 | 13 | June 22nd, 2008 02:49 PM |
| check engine light | gwilkrrs | 99-04 | 1 | June 8th, 2008 08:27 AM |
| check engine light | 02ATIstang | 99-04 | 24 | May 22nd, 2007 06:03 PM |
