How much abuse can the 96 teksid take?
Old November 11th, 2009, 10:32 PM   #1
4valvegt's Avatar
03 Cobra
4valvegt is on a distinguished road
I am building a turbo kit for my 4valve project the bottom end is all forged but im wondering how much abuse and rpms the stock b heads can take?
Old November 11th, 2009, 11:23 PM   #2
98Cobra_sleeper's Avatar
1998 mustang cobra
98Cobra_sleeper is on a distinguished road
well i heard SHM builds teksid blocks that handle up to 1300hp, and i've seen cars online revvin to 8k.
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup)
comin soon...ON3 turbo kit, PTE7175
Old November 12th, 2009, 12:41 AM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the teksid block itself can take a ton of abuse.
Old November 12th, 2009, 12:44 AM   #4
1970 Mercury Cougar.
JC316 will become famous soon enough
The block and crank can take a crapload. The rods are still the same crappy pressed powdered ones.
Old November 12th, 2009, 12:49 AM   #5
4valvegt's Avatar
03 Cobra
I know the block itself can im just wondering if the heads will be any good? Or would i be better off using my 2 valve patriot stage 2 heads? The only thing that concerns me is that this motor only had 50k miles on it and when i took off the valve covers i found loose rockers layin in the head like someone over revved it and they flew apart.
Old November 12th, 2009, 12:52 AM   #6
4valvegt's Avatar
03 Cobra
Does anyone know if i could use the 97 mark 8 intake manifold on this motor? and is it possible to remove the intake runners without any problems?
Old November 12th, 2009, 03:58 AM   #7
Yes, you can use the 97 or 98 mark VIII intake. You have to buy the IMRC delete plates to get rid of them.
Old November 13th, 2009, 09:25 AM   #8
bitemark46 has a spectacular aura aboutbitemark46 has a spectacular aura about
The block and heads will hold more power than your wallet can afford.
-Mark-
98' N/A Cobra (Stock longblock)
11.79 at 114.64 (1.62 60ft)
Old November 20th, 2009, 01:05 AM   #9
CammedMysticCobra's Avatar
Mustang MystiqueCobra2004
CammedMysticCobra can only hope to improve
Send a message via AIM to CammedMysticCobra
OK well bottom line is when I got my teksid found out so much sickness. Here come short tekside history lesson. Teksid was a company that ford of course contraced to put into the all 96 - 98 cobras some of these ended up in the a couple of the 2001 Cobras. Now How much abuse it can take the actual block. The reason ford went with Teksid is a Italian manufacture who makes blocks for Ferrari yeah get the fuck out here is right but wait they also make the blocks for Lamborghini, Fiat, Porsche and so rember all these cars deflty dont just rev to 6500 or 7 so this all equalls good for about 1500hp and more than you can throw at it for now lol.
Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne
http://www.youtube.com/user/MysticCobra04
Sold not lost and will never be forgotten.
Old November 27th, 2009, 09:30 AM   #10
Ryan Paymaster's Avatar
1996 Ford SVT Cobra
13.36@102
Ryan Paymaster will become famous soon enough
Send a message via ICQ to Ryan Paymaster Send a message via AIM to Ryan Paymaster Send a message via MSN to Ryan Paymaster Send a message via Yahoo to Ryan Paymaster
Yeah, even if your wallet can afford to do 1200 horsepower it's still going to handle more than you can afford. If you're going faster than that then you probably can't afford it anyways. 7 second cars take a lot of money to keep up.
Slowly but surely creeping into the 12's on a stock N/A block...
Old December 3rd, 2009, 12:06 PM   #11
96 Mystic SVT Cobra
96SNAKE is an unknown quantity at this point
Send a message via AIM to 96SNAKE
Does anyone know for sure on how much this 96 block can take before anything blows? In other words, pistons and rods? I heard more than 440 N/A on a stock (all together, internally) that you could be looking for problems. Trying to decide if I should just stay N/A and do bolt ons or get the KN 2.1L s/c. At about 7psi it puts me at 426 crank horsepower and 430 crank torque..
Old December 5th, 2009, 12:03 AM   #12
F8TL BYT's Avatar
98 Cobra
13.82 @ 98.86
F8TL BYT is on a distinguished road
They can handle anywhere from 400-550whp. The reason i have so much space between the numbers is because it all depends on how good of a tune it is and how much you beat on it.
MM Cobra Club #8
Old December 5th, 2009, 12:09 AM   #13
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
it all depends on how everything acts with each other. the blocks can handle a good amount with the right parts working the way they are supposed to.
BUILD 2 IN PROGRESS
Old December 5th, 2009, 05:26 AM   #14
96 Mystic SVT Cobra
Okay thanks. I might be going the supercharger route then here pretty soon. I just don't want to throw a rod or piston. I'm going to keep the engine all stock internally. Is the tune that comes with these superchargers able to be retuned through a dynotune or a preloaded tune?
BTW, your car is beautiful!!
Old December 5th, 2009, 10:17 AM   #15
1996 Ford SVT Cobra
13.36@102
A KB isn't going to destroy your block. Extra strain on internal parts and such? Sure.
Everything should hold up but that doesn't mean it will. I managed to annihilate the spider gears on a car with just 300RWHP or so at the track with drag radials. Your stock transmission could probably go out soon depending on how you beat on it. (Weak spot in the car.)
If it's just a street car and you're just using it as a sweet cruiser then it may last forever.
Old December 5th, 2009, 10:43 AM   #16
96 Mystic SVT Cobra
Ryan, that's exactly what I'm going to be using it for. Thanks man.
Threads Similar to: How much abuse can the 96 teksid take?
Alcohol Abuse AMmuslGT The Clubhouse 7 November 3rd, 2009 10:29 PM
Abuse of rubber... got a quick question Fijistudios 5.0 Mustangs 11 March 14th, 2009 09:48 AM
Engine abuse. jeff V6 Mustangs 64 January 4th, 2007 08:46 AM
