Car turns off in neutral after WOT - Page 4
Old January 2nd, 2010, 06:43 AM   #61
96 Mystic SVT Cobra
96SNAKE is an unknown quantity at this point
Send a message via AIM to 96SNAKE
Well guys.. I finally got around to switching out the stock airbox back in and taking the FIPK kit out... It doesn't cut off anymore! I'm going to throw in a K&N air filter, I hope they're are actually some advantages to switching back to the stock airbox. Anyways, if anyone wants my FIPK kit just let me know.
Old January 2nd, 2010, 08:34 AM   #62
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
this is the reason why I am thinking of going with a C&L and ditching my JLT. Some people dont experience these problems with fenderwell while others have to either live with it or go back to stock, as in your case. How does she idle now?
BUILD 2 IN PROGRESS
Old January 2nd, 2010, 08:45 AM   #63
96 Mystic SVT Cobra
Hey wraitherx. She idles like the day I bought her, man.. And she pulls very good, too. I love this car, man. Why are you thinking you should go with the C&L?
Old January 2nd, 2010, 09:58 AM   #64
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
Well, I have the same problem that you were experiencing. I thought that with the cams and engine work that I needed a better tune so i got Joe (Tricktuners) to tune her up. His tunes were spot on and now my stalling/idling issue isnt as predominant as before. What used to happen almost everyday is now down to every once in awhile, once or twice monthly now. So I am grateful to him for always taking care of me. I started just like you checking every little thing and ruled everything out and then I took some abs plastic and created an airbox to surround the front of the air filter to stop the turbulent air from entering during decel and that helped out and has pretty much went away. I dont really like JLT's design, for numerous reasons, so I wanted to get a C&L so that i can just do away with the problem. Id rather have something fixed then apply a band aid to it. Know what I mean?
BUILD 2 IN PROGRESS
Old January 2nd, 2010, 10:32 AM   #65
96 Mystic SVT Cobra
I definitely understand what you mean, man. I've heard several other guys say that they don't like JLT. Why don't you like it?
Old January 3rd, 2010, 02:19 PM   #66
03 SVT Vert/'00 V6 Vert
pilot37 is on a distinguished road
Originally Posted by Trick Tuners View Post
This is common when the air filter has the maf behind it, and is exposed to high velocity wind. When people pull the headlight its even more common. It could be something else, but if i described your setup, then that is the issue. The reason behind it is that the air blows thru the filter onto the maf, but does not really go into the engine. The ecu adds a ton of fuel to compensate for the huge rush of air seen at the maf, but the air never makes it in so it stalls out. If this is not your setup, then the tune could use a little more adjusting to dial it in better.
I had a similar problem after installing my carbon fiber JLT CAI. Engine would cut off at idle. Solution: Make sure you tighten all the hose clamps when installing any aftermarket intake!!! My Termi' was throwing a code saying that both banks were lean, this is because one of the hose clamps weren't tight enough so the engine was not getting the air that the MAF was telling it it was; so it was injecting more fuel.
I tightened all the clamps properly and have not had any problems since.
2003 Terminator--JLT C/F CAI, Magnaflow Cat-back
MM Mountain Crusader Club--MMMCC link
MM Cobra Club #60
Old January 4th, 2010, 05:09 PM   #67
Poppajac's Avatar
2001 GT
Poppajac is on a distinguished road
Hey guys,
I have a supercharged 01 mustang that is having about the same problem. The difference is that the car is an AOD and seems to cut off when downshifting at stop signs and such. It doesn't do it everytime but when it does cut off I put the car in neutral and it starts right back up. I was told it could be the car loading up because of the supercharger but that didn't sound right to me.
I posted on another thread that I was adding some LEDs to my car for a meth injection and once I installed them my fuel pressure gauge started reading 4 or 5 psi rather than the normal 20psi. Now I am wondering if I have knocked something lose.
Poppa
Old January 22nd, 2010, 03:24 PM   #68
stevo56 is on a distinguished road
Mine was doing that trash, drove me crazy. I just got use to it and downshifted quicker. Until it happened to wifey when i let here take it for the day. Needless to say she doen't ask to drive it anymore. Kudos to the faulty IAC.lol
Old January 22nd, 2010, 04:47 PM   #69
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
sometimes when i turn my car on it rpms go up then down to were it turns off, happens to me once in a while i hate it....at stops tha rpms are so high, i tap tha gas and they go down, im thinking my bby tb aint closin all tha way.
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old January 22nd, 2010, 05:36 PM   #70
MM Cobra Club #60
Old January 23rd, 2010, 05:15 PM   #71
Is that sea foam trick in the oil good with sythetic oil? Had a buddy mention sea foam to me the other day and swore by the stuff, but was unsure about mixing it with a synthetic motor oil. Actually can't wait to try it. I can only imagine the sh*t that is going to come out of it!!
Old January 24th, 2010, 02:09 AM   #72
BoostFiend's Avatar
'03 Cobra, '89 +'91 Notch
11.63@120.08, Cobra
BoostFiend is on a distinguished road
As some others have mentioned it is pretty common with our car's, most notably the Terminators. Mine did it a few times, but ever since I got it retuned it hasn't done it. *knock on wood* It has to do with the returnless fuel system. Never heard of it being a problem with the intake. lol Is your car tuned?
Old January 25th, 2010, 04:01 PM   #73
I have never had the car tuned. I haven't really added too many things to it yet. Do they make a huge difference with just having done the basics of opening up with a CAI, exhaust, timing, and underdrive pulley kit? O figured the computer could adjust to the difference the mods made. Am i mistaken? Many posts in regards to this has said it could be too much fuel being sent by the NAF being fooled. Would adding a spark booster like the ones offered by MSD make a difference by providing a stronger and more continuos spark to brun off that fuel?
Old January 25th, 2010, 04:33 PM   #74
97 Cobra
acidtonic will become famous soon enoughacidtonic will become famous soon enough
Just dont go crazy the first few times if its really clogged.
I would go progressively stronger until you reach what I recommended (1/3 can).
Think of it this way, whatever breaks off has to go somewhere. I'd rather break off small pieces with a less potent mixture over a few times instead of a potent mixture first time that lands big solid chunks in your oil pan.
Just start light and get stronger and stronger. By the time you run that final potent mix, all the major stuff will have broken off and you will get the remaining stubborn pieces.
Just read the label about other products.... many say to drop the oil pan after and get the big deposits that fall out otherwise it could damage/clog something. I'd rather not do that, so my first few times knowing no one ever seafoamed the car, I used a smaller quantity.
** This holds true more for crankcase applications but still the first few in the PCV I would let sit longer with a smaller amount. **
Converted to the Dark Side.
06 Apex Silver Evolution IX GSR
- Turboback Exhaust, Tune
- Wideband O2, Trustz backlight gauges, Apexi turbo timer
- Stock wing, but soon to be wingless.
- Guessing 280-310 at the wheels.
02 Red Escape V6 4x4
Threads Similar to: Car turns off in neutral after WOT
car turns over but wont turn off 01dutchGT Classic Mustangs 4 October 27th, 2009 09:46 PM
car stalls on turns carlos 99-04 1 June 16th, 2009 01:04 PM
neutral switch???? Frankenstang 5.0 Mustangs 3 September 8th, 2008 02:46 PM
Always Make Sure Its In Neutral B0B The Clubhouse 8 December 19th, 2007 09:04 PM
car turns off hmotes 5.0 Mustangs 8 June 12th, 2007 07:09 PM
