120lb injectors
I figure if any kind of people would know it'd be you guys or maybe high boost 5.0s
Anyone know where to get some low imp 120lb injectors if possible a place that sells them with a flow sheet
Moderator
here you go High Performance New Fuel Injectors - New Lucas - 120lb LUCAS ev1 LOW IMP - Fuel Injector Connection
![]() ![]() BUILD 2 IN PROGRESS |
hmm says aftermarket computers. Didnt plan on AEM until a little later down the road. only thing is i dont think 80lb injectors and E85 will make 500whp+
Moderator
yeah, every place that im seeing is saying that with those injectors that you will need a stand alone unit to drive them. here is another site Acceleronics sells flow matched injectors
hmm that site has 95lb injectors. that should be enough for about 540-550rwhp with E85. I'll call them tomorrow and see if they can be used with a stock computer. If not i'll have to settle 100 or 110
Moderator
sounds like a plan and let us know how it turns out.
will do thanks for the help
2000 Mustang
14.10@96.75
have you looked at RC Engineering?
2000 V6 vert 2003 Lightning |
KB'd GT
120#?? Are you running 30+ psi? 80s wont work?
no i have not? I will try googling them. thank you. Assuming I can use the stock computer? A buddy told me last night i can run 96lb injectors. 96lb should be enough to make 500 at least.
Once the built motor goes in Im going to be looking at putting a full stand alone AEM in the car anyway so i can run 160lb injectors or 1600 w/e probably 13-15psi on the stock motor. 500whp on E85...IF the 80lb injectors make it my fuel pressure will be 60+psi probably and injectors on 95+% duty. kinda risky to run IMO Will check them out, Thank you sir
KB'd GT
Werd. E85 sucks the capacity out of your fuel system! (~30-40% more capacity needed compared to gas) But gotta love the octane! I would only get about 100 mi per tank!
I called up RC but they're biggest option w/o stand alone was 71lb high imped?
MMR didnt pick up but i see they sell the 96 and 160s
#14 | |
Ive seen so many cars get tuned on E85 and make nice power. some cars make the same power as race gas or just a little more then pump but run MUCH stronger. So i know the pump and rails i'll be going with will be more then enough. i just need the injector for it. I'm using a 10gallon cell so i dont know how long that'll last me lol
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
quick question...dont you need EV6?
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
BYAHHHH!
2001 Mustang GT
13.874
I just dont understand why u need 120lbs injectors for 500rwhp? Just because they are low imp injectors and so they run cooler? WIll you need to get a different driver modular?
The injectors are for my V6, i have adapters for w/e injectors i go with.
for 500whp 80lb injectors will be limited 80lb injectors are a little higher then 800cc injectors 80lb injectors on my V6 would be good for about 700whp on my car race fuel. using E85 as the guy from Trick tuners said you need to maximize your fuel system 30-40% more! so if you are aiming for 500whp you would have to setup a fuel system for about 800whp or you can look at it if you have a fuel system on race or pump that will make 1000whp safe then on E85 you're only good for about 600-650. but E85 has a good octane rating and makes great power and cost about $2.50 a gallon. vs C16 at about $80 for 5allons. some places ive heard you can get for $45 but either way thats $9 a gallon. i dont care about the cost so much, i just want to try the E85. after the setup with the V6 is done im throwing in a new motor anyway. not a v6 or v8 something different
BYAHHHH!
2001 Mustang GT
13.874
oh so with E85 you have to have a fuel system for more power? idk man I am confused..oh well I wont use E85 ever but thanks!
#19 | |
stock tank with a precision fuel hat for 2 pumps, all 2 GT40s, 2 modded FPDM modules and wires. -8 line and then the injectors will probably have the same issue im having but doing all that is wasteful IMO unless you have the cobra tank other wise you spend $600 cobra tank $400 on just a fuel hat!! $400 for 3 pumps modded FPDMs $400 FPDM wire upgrade-$80 to the fpdm $1800-$1900 in fuel .....you need lines to but you'll need it for any high hp setup vs fuel cell-$100 external 1000hp pump- $300 regulator-$200 done...you need a return line but w/e another $50 if you're getting ripped off so for $650 you've built a fuel system that will much surpass the cobra tank setup and be safer
BYAHHHH!
2001 Mustang GT
13.874
oh ok well you when put it like that haha
THats tight. yeah fuel setups are pricey.
Threads Similar to: 120lb injectors
| injectors | wishIhada5.0 | 99-04 | 7 | February 3rd, 2009 09:23 PM |
| injectors | riddlee josh | V6 Mustangs | 3 | November 29th, 2008 01:46 AM |
