Bad TPS
Old December 19th, 2009, 01:00 AM   #1
OcOnnor220 can only hope to improve
Bad TPS
I need to know if the throttle position sensor on my 03 Cobra could be bad. Will replacing it make the car idle normally and are they year or engine specific, I found one at cj pony parts but Im not sure if it will fit to my motor.
Old December 19th, 2009, 01:35 AM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
I got a ford factory one from Steve @ Tousley Ford Parts Depot. The only way to tell if it is bad is by doing a resistance test on it between the reference wire and ground wire IIRC. Just cause your Idle isnt normal doesnt mean that it is bad. It could also be a vacuum leak or even a bad IAC. What are your mods so that we may further assist you with this problem you are experiencing.
BUILD 2 IN PROGRESS
Old December 24th, 2009, 04:10 PM   #3
Well the idle is more than a little off, not only is it dropping low and stalling EVERY time im at a stop, it also gets stuck at 1100 and stays there unless i gently pump the gas pedal...its just gotten worse in the last few weeks and Ive already sprayed the IAC but that didnt seem to help. I think the TPS is cheap but these scanners and tuners used to test things like this arent cheap...Thats why I figured Id just replace it. I have no mods, just an SLP loudmouth 2 catback, thats it. I mean it started out idling funny and dropping low but then bumping back up, then it started stalling once every time I would start it up and leave work...Now its doing it several times coasting to a stop until the cars been driven a few miles...Really becomming a P.I.A.
Threads Similar to: Bad TPS
Symptoms of a bad TPS? PacificMustang01 V6 Mustangs 13 February 19th, 2011 01:20 PM
TPS mustangmad 94-95 4 October 17th, 2009 08:06 PM
Bad TPS???? ross15373 94-95 3 October 7th, 2008 09:25 AM
tps cali 5.0 5.0 Mustangs 16 May 5th, 2007 07:31 PM
TPS on my 87 GT cobralini 5.0 Mustangs 0 July 20th, 2006 03:36 PM
