Getting different rims... (going wider?) - Page 2
Old December 29th, 2009, 11:57 AM   #21
96 Mystic SVT Cobra
96SNAKE is an unknown quantity at this point
Send a message via AIM to 96SNAKE
This is another reason why I ask so many questions. I'd like to know as much as I can about these cars. Thanks again, Dex.
Old December 30th, 2009, 01:17 AM   #22
forcefedcobra's Avatar
2003 SVT Cobra
forcefedcobra will become famous soon enough
Like Ryan said tires on the 17's will be much cheaper. 1/2 the price in some cases vs. an 18. I know you said that you dont want your speedo to be off if you jump to 18's. You wont have to worry about that as long as you get a shorter sidewall. 275/45/17 will be similar rolling diameter as a 265 or 275/35/18 so you wont have to worry about your speedo. It's all about what you want and if you can afford those wants.
Old December 30th, 2009, 07:43 AM   #23
96 Mystic SVT Cobra
forcefedcobra, thanks for the advice. I think I came to the conclusion. I plan on getting the 17x9" fr500 on all four tires. My car will be a daily driver and switching to 18's but getting a shorter sidewall will actuallt decrease my handling so I'm trying to get the best handling performance/potentional for a daily driver. So switiching yes to the 17x9's would increase my handling since I'm going to a wider tire but still keep the stock sidewall.
At least this is what I plan on doing...
Old December 30th, 2009, 02:39 PM   #24
2003 SVT Cobra
a shorter and consequently stiffer sidewall will handle better in the twisties versus a tall sidewall actually. However if it is your daily 17's will be much cheaper and if you go 17x9 on all 4 corners you will be able to rotate and get more life out of them. I have 18x9 and 18x10.5's so I cant rotate but my front tires have lasted forever and I dont mind getting new rear tires every 12 to 18 months especially since I normally run a DR on the back with over 600 rwhp.
Old December 30th, 2009, 03:11 PM   #25
1997 mustang gt
jhills2 is on a distinguished road
I as well am deciding still on which rims to get. My brother is giving me 3 275/40/17's so i was going with 4 17 x 9 antrhacite Fr500's all around
I was going to use my 1' wheel spacers out back but am now debating on wheter or not to sell those and get 17 X 10.5 and buy 2 315's out back.
Either way, id stick with 17's if i was you. Its not going to be a huge difference with handling honestly. I am in college so money is an issue!
Eaton SC 6psi, 4.10 gears, PI cams, CAI, 70TB, OR-H, Bilstien struts/shocks, B springs, MM C/C, B&M trans cooler, 10th anny cobra brakes
Old December 31st, 2009, 02:40 PM   #26
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
Yeah, that's the bummer I've been thinking about with all the talk of wanting to rotate. You can't run a drag radial if that's the case. That would kind of suck, because I honestly feel that a good, sticky tire is one of the best performing mod for the money even though they don't add a bit of horsepower.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old December 31st, 2009, 04:11 PM   #27
2003 SVT Cobra
yep and that is why I am going back to a drag radial again. Cant be letting you get the jump on me waiting to get enough traction to give you the 3rd gear fly-by anymore. LOL! It's like Dewayne's car. What good is a 900 rwhp turbo mustang that only runs 12's? I look at rear tires like fuel, oil, brake pads, etc. It's just something that needs changed. If I didnt want to deal with that then I would have a normal car with 60k mile tires that couldnt get out of it's own way.
did you get my text about the bowl bash?
Old January 21st, 2010, 05:06 PM   #28
96 Mystic SVT Cobra
Hey guys i ended up buying some rims, I need to get some tires though. I want to get some all-season tires since my car is a daily driver. I found some for $115 in 255/45/17 and 255/40/17. My question is this. I just bought 9" wheels should I stick with my stock 245/45/17 size or go with a 255/45/17 or a 255/40/17? What are the advantages? I'm looking for traction, longer tread lifem and better cornering to make this car more fun to drive.
Thinking about these tires. Kumho Ecsta ASX
Thanks again, fellas.
Old January 21st, 2010, 05:23 PM   #29
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I like the ASXs, I ran a set of them for about 20k. I'd go with 'em again if I needed a cheap allseason.
O o
/¯/______________________
\_\
Old January 21st, 2010, 05:26 PM   #30
96 Mystic SVT Cobra
How long do you think those will last for?
Old January 21st, 2010, 05:36 PM   #31
Mine gave me really good dry traction for about 15k miles, and the wet traction was still good when I took them off at around 20k. I still have the tires, they're just not mounted on anything, and they're not yet on the wear bars. If I get into drifting, I'm gonna put 'em on my 17x9s and burn the rest off.
O o
\_\
Old January 22nd, 2010, 05:07 AM   #32
96 Mystic SVT Cobra
Oh, okay. They souns like their tread life might be around 40K?
Old January 22nd, 2010, 11:29 AM   #33
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
18inch tires are pricey, luckily i got a good deal on some 295 toyo t1r, so if you wana not spend so much go with 17s you can get tires for cheap compared to tha 18s
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old January 22nd, 2010, 12:07 PM   #34
I wouldn't say that.
O o
\_\
Threads Similar to: Getting different rims... (going wider?)
wider the better? 98Cobra_sleeper 4V / SVT 10 September 23rd, 2009 08:34 PM
Is there any way to put wider tires on the stock rims? vomitron 2005 - 2010 9 July 8th, 2009 01:20 PM
Making Rims wider Blackblurr_00GT Modular Mustangs 3 September 11th, 2008 11:18 PM
Which is wider? 84 or 94 gt? BlackSunshine 5.0 Mustangs 3 June 28th, 2008 02:06 PM
wider is better aday28 V6 Mustangs 14 January 13th, 2008 08:32 PM
