99 Cobra / 96 GT vert.
N/A
Vehicle Sways from side to side.
Not to long ago I installed new suspension, brakes, rims and tires. Tokico HP shocks/struts and springs, 275/35/R17x9 up front and 315/35/R17x10.5 in the rear. My problem is when im cruising or decelerate my car sways from side to side as if I had a trailer on the back. I have had an alignment. I am trying to figure what else it might be. Any help guys, thanks.
N/A
Does anybody have any expierence with this?
2003 SVT Cobra
N/A
I think so, just feels like the back of the care is swaying from side to side when I drive in a straight line. If i accelerate fast it does not happen, but as soon as I decel it is all over the place.
N/A
I think I found the solution. I think the term is called "rear roll steer". Does this sound familiar to anybody? If this is the problem then all I have to get is a rear roll steer kit. Let me know if you guys have had this problem
"Steeda's rear roll steer kit helps elimiate rear roll steer by correcting the bump steer geometry in the rear of IRS Cobra Mustangs. The design of the rear IRS (independent rear) suspension on '99-'04 Cobras is great for ride quality, but introduces bump steer characteristics like you see in the front suspension. The toe changes from bump steer produce unwanted rear toe changes resulting in unwanted steering inputs from the rear suspension. This produces adverse handling characteristics. This kit from Steeda allows you to fine tune rear bump steer geometry to improve steering response and handling balance." |
#7 | |
2003 SVT Cobra
N/A
I know the the sway is coming from the rear. When I brake I do get a little bit vibration in the front when I brake that is because the rotors need to be turned. I will try this and see how it works.
#9 | |
2003 SVT Cobra
If you do end up doing the rear bumpsteer kit remember that it has to be setup by bumpsteering the irs. This will either be added cost of having someone else do it or added cost of purchasing or building a bumpsteer gauge to do it yourself. If you decide to do it yourself send me a PM and I'll find a video that Bruce at full tilt boogie racing made explaining how to do it yourself. |
N/A
I appreciate all the advice forcefedcobra.
2003 SVT Cobra
Threads Similar to: Vehicle Sways from side to side.
| MMR cold side & hot side ??? | SilverGT04 | 99-04 | 2 | September 24th, 2009 10:03 AM |
| Mustang and Camaro - Side by Side | Fluffy The Rhino | The Clubhouse | 26 | March 25th, 2009 11:39 AM |
| WTB Side Scoop Insert 2000 mustang Drivers side | bushden | V6 Mustangs | 1 | February 28th, 2009 07:45 AM |
| the mach 1 & the v6 side by side...check it out! | supermachone | The Clubhouse | 38 | August 17th, 2008 09:45 PM |
| Holy Crap One side of axle is centered, one side is not | OTreborO | 5.0 Mustangs | 6 | June 6th, 2007 12:04 PM |
