Intake spacer for machs and cobras
Old January 9th, 2010, 07:29 PM   #1
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
Is there any ideal size spacer to use between the upper and lower manifold? I have seen and read a little bit about them and am curious about what height does. I can make one for myself at work and am not sure how thick I should make it.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old January 9th, 2010, 09:56 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
if i remember correctly anything over 1/4" then will into problems re-bolting your EGR valve back on. Thats only if you still have it. Other then that, longer bolts and gaskets on both sides and thats it.
BUILD 2 IN PROGRESS
Old January 9th, 2010, 10:07 PM   #3
It's in the details Mod!
M.P. Cobra Fan's Avatar
01 Cobra Vert
Nov 09/10 ROTM!
M.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond repute
I have a 3/8th" from Karkraft that i will be installing soon. I have heard that the EGR can be a PITA to put on, but it can be done. I will do a write up when I install it
Pinup in signature by loish.net
Modded Mustangs Cobra Club#007
Military Crew E5
VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07
Old January 9th, 2010, 10:22 PM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
Yeah i didnt know exactly what size they were talking about where the problems would occur.
BUILD 2 IN PROGRESS
Old January 10th, 2010, 12:45 AM   #5
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Paul's High Performance also makes a 3/8s spacer. Roy on the Mach 1 Registry makes bigger ones, but I don't know what modifications are needed at what size.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old January 10th, 2010, 01:44 AM   #6
Is the game, Ross is the name.
6DXR's Avatar
1998 M3,2K8 Ninja 250
Faster Than Fapsmith's Asian Girl
6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all
Send a message via AIM to 6DXR
I have a 3/8
I drive a 1998 BMW M3. I used to drive the sexiest Mach 1 in existence. But now I am a 3uroslut
Old January 10th, 2010, 03:13 AM   #7
2003 gt
5.4 32v on the way
I am not worried so much about egr issues, its already blocked off on the manifold. I have access to what I need to make the spacer myself so im just wondering what kind of height seems to work out best. With what I have available to me I can go as far as ~1.5 inches thick. What does the spacer thickness do for you?
Old January 11th, 2010, 02:02 PM   #8
bitemark46 has a spectacular aura aboutbitemark46 has a spectacular aura about
99+ benefit from it since there intake volume is much smaller than the 96-98 cobras. But by adding plenum volume all you really do is move your peak power higher.
-Mark
-Mark-
98' N/A Cobra (Stock longblock)
11.79 at 114.64 (1.62 60ft)
Old January 11th, 2010, 03:06 PM   #9
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Intake spacers make some pretty good torque for the cost to buy/make them.
Old January 11th, 2010, 04:18 PM   #10
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
any intake spacers for the 96-98 cobras?
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old January 11th, 2010, 06:56 PM   #11
2003 gt
5.4 32v on the way
I am trying to build a top end heavy 4v 4.6 and I just want to make the proper sized spacer. How big is too big?
Old January 11th, 2010, 07:15 PM   #12
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
I don't know why it would be any differen't even if it does have a bigger intake. More room = more air.
Old January 12th, 2010, 10:49 AM   #13
T.B.A
^ so is that a yes? were can i buy one?
Beauty & The Beast
Old January 12th, 2010, 12:56 PM   #14
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
I hit quote on the wrong guy. That was meant for DickH's question. As far as I know, no one makes an intake for your Cobra.
Old January 12th, 2010, 02:53 PM   #15
T.B.A
its cool, dam someone should patent one...anybody else, has anyone seen intake spacers for tha 96-98 cobras?
Beauty & The Beast
Old January 12th, 2010, 09:12 PM   #16
2003 gt
5.4 32v on the way
So is it safe to assume that a 1/2inch spacer will be fine to use? What are typical gains from a spacer?
Old January 12th, 2010, 09:27 PM   #17
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
On Machs you typically see just a couple horsepower but an increase of ~10rwtq over peak. The bigger you go the more power you see. I don't know how it would work on the 96-98 Cobras.
Old January 13th, 2010, 09:05 PM   #18
2003 gt
5.4 32v on the way
I think im going to try to go with a 1/2inch spacer. Why is it I don't really see anything above 3/8? Is it really just egr issues or is there anything else I should watch for?
MMR sells spacers for the 96-98 cobra manifold for 139.
Old January 13th, 2010, 10:32 PM   #19
01 Cobra Vert
Nov 09/10 ROTM!
It is mainly an EGR thing I believe. I saw one on SVT that someone made and they had to many problems with the EGR for it to work.
Military Crew E5
Old January 14th, 2010, 03:17 PM   #20
T.B.A
sweet mmr does have spacers for 96-98 cobras, you guys think they are worth it and make a difference?
Beauty & The Beast
Threads Similar to: Intake spacer for machs and cobras
Intake Spacer JustinsAVOID V6 Mustangs 4 August 17th, 2008 12:18 AM
AM Intake spacer JStang14 99-04 11 February 15th, 2008 05:47 AM
Tell Me. Machs, Cobras, and Others. stanggirl Modular Mustangs 26 November 21st, 2007 01:14 AM
