what causes this
Old January 12th, 2010, 11:15 AM   #1
2003 svt cobra
nyjetsfan4lif3 is on a distinguished road
Send a message via AIM to nyjetsfan4lif3
what causes this
my car kidna lags a lil when i go wot , like cuts out a lil bit here n there , what could be causing this
2003 svt cobra - jlt rai , steeda 2.8 , diablo tune
06 gt -auto , 4.10 , udp , cams , lt headers , x pipe , axle back , cai , 93 oct tune , cmdp , twin 62 tb - sold
Old January 12th, 2010, 11:53 AM   #2
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about
You should start by checking the basics, plugs wires fuel filter.
We need alittle more info for instance. Does it shudder out of the hole or higher RPM's?
i usually wave first, but if the guy is sexy and i'm drunk, i might lift up my shirt and flash him as well.
MM Cobra Club Member #61
Old January 12th, 2010, 12:12 PM   #3
2003 svt cobra
mostly at higher rpms
Old January 12th, 2010, 02:54 PM   #4
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
sounds like a fuel pump to me.
Old January 15th, 2010, 03:40 PM   #5
97 Cobra
acidtonic will become famous soon enoughacidtonic will become famous soon enough
Could be a clutch with a failing stock quadrant.
Tight normal feeling clutch but at WOT it would slip just enough to feel like a misfire. It would do this about 2 or 3 times from 3000-7000.
Quadrant wasnt holding the clutch tight enough. It was of course too late when I finally figured out why my 3 month clutch was already slipping. Most of it had already worn away.
If you go the misfire route and still cant figure it out, take a look at your quadrant. Biggest symptom was the hesitation happening more and more while hot.
Converted to the Dark Side.
06 Apex Silver Evolution IX GSR
- Turboback Exhaust, Tune
- Wideband O2, Trustz backlight gauges, Apexi turbo timer
- Stock wing, but soon to be wingless.
- Guessing 280-310 at the wheels.
02 Red Escape V6 4x4
Old January 15th, 2010, 08:15 PM   #6
ZOOTOXIN's Avatar
ZOOTOXIN will become famous soon enough
maybe the wheels are breaking loose at WOT high RPMS...do you have traction control and was it on? Sounds crazy but it happens to me if the road is cold.
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
Old January 15th, 2010, 08:38 PM   #7
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
I had an issue with that and it turned out to be my alternator.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
