Front rear main seal removal/install
I have an 03 Marauder that has the motor out of it right now because of a transmission problem that resulted in a rebuild. While the tranny is out I wanted to fix a oil leak I have at the front cover and the oil pan.
My questions are in regards to removing/installing the front and rear main seals along with the oil slinger. Can you use something besides the OEM pullers and installers for the 2 seals and the oil slinger? The OEM tools are really expensive and I was wondering if a hook type race seal puller could be used to remove and bearing race seal driver set could be used instead to install. If I have to buy the OEM pieces I will but do not really want to drop $300-$500 if I can help it. Thanks for any help you guys can provide. |
Moderator
yes you can, i picked one up from and autoparts store for like $5 and used that. just make sure that when you do use it but a towel in between the cover and tool (where you will make your contact point and leverage on) so that you dont mar up your timing cover. I had a socket about the same size as the oil seal and then tapped it in, wasnt hard at all.
![]() ![]() BUILD 2 IN PROGRESS |
Thanks for the info. I am assuming this is for the front main seal only. Looking at the rear I think I could use a small punch to pivot it out but I am worried about damaging the slinger piece. I have also read that I don't even need the slinger and it isn't necessary to reinstall. Any truth to this or shoudl I make sure I reinstall it?
Moderator
i did the front and thats how i did it. if im not mistaken i believe that rear is a little harder to get out
Got it, thanks for the help. I just pulled the rear seal plate and both the rear seal and slinger came off with it. The slinger just popped out once the plate was loose.
Anyone know if I have to reuse/replace the slinger or can I just leave it off? I hear it isn't necessary and can actually free up a few hp. |
Threads Similar to: Front rear main seal removal/install
| Front main seal install | flattusmaximus78 | 5.0 Mustangs | 2 | September 3rd, 2008 09:45 PM |
| how to install rear main seal 1995 f-150? | 969800gt | All Other Vehicles | 0 | May 5th, 2008 08:45 AM |
| 5.0 front main seal | lugthug713 | 5.0 Mustangs | 1 | August 23rd, 2007 09:38 AM |
| rear main seal? | marks87gt | 5.0 Mustangs | 4 | April 26th, 2007 05:16 PM |
| Rear Main seal | 1gunner23 | 5.0 Mustangs | 5 | May 11th, 2006 11:53 PM |
