03-04 heads on 1996 cobra
Has anyone put 03-04 heads on a 1996-98 cobra .is it a bolt on. what about coil pack I know you will need a different intake manifold or supercharger anyone out there done it
thanks hedgehog (1996 mystic cobra ) |
9.74@142
Many have swapped to 03/04 heads and made big gains over the b head combo.
If you are not planning on going with aftermarket cams, keep your 96-98 inatke cams, they have the most duration out of all the stock cams, the exhaust cams are essentially the same. You will need an intake that fits those heads (99/01 cobra, mach 1, or 03/03 supercharger set up). Unless you can find a complete 03/04 Cobra blower swap, IMO your better off putting it together with all the later N/A 4v parts and then going with a centri blower like a D1sc or an F1a. So the major items that you need to set it up: *03-05 4v heads (03-04 Cobra, mach1, maurader, and aviator all have the same heads, with the 05 aviators bieng the best/latest revision castings) *03/04 Mach1 intake (best out of the bunch), 01 Cobra intake, post fix 99 cobra intake. Stay away from the pre fix intake unless you plan on having a lot of work done to it *99-04 mustang 4v (mach or cobra) specific parts: - Throttle cable and bracket - Aftermarket fuel rails that fit the 99-04 intakes, must add an ADJ fuel pressure regulator -CAI/intake tubing Thats all I can think of right now. You can keep your valve covers and coil/wires setup.
2003 gt
5.4 32v on the way
So the chain cover and whatnot will still bolt up fine? It really is just a head/intake swap and done as far as the motor goes? What are the differences between the mach and cobra manifolds if the mach is better?
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
#4 | |
9.74@142
The intakes are all based on the same casting, but it has improved since its introduction in 99 with revisions in the casting and machining.. The 99s that did not have the "fix" (factory recall to improve poor performance) had a lot of extra casting flash. The post fix 99 intakes were extrued honed and flowed better. The 01 Cobra intake as cast flows better then both 99 intakes. The 03/04 mach intake flows better then all the rest (slightly better then the 01 Cobra). Nazman had a thread on SVTp that showed how to identify the difference between them all. The mach inatke is obvios with it missing the cobra symbol on the plenum. But it may be hard to diferentiate the difference between the cobra intakes if you are buying one from someone that did not directly remove it from the car.
2003 gt
5.4 32v on the way
How can you tell what year the heads were made in? How do I know for sure if I have 05+ heads?
#6 | |
9.74@142
2003 gt
5.4 32v on the way
So any way of knowing what s73- RFYR3E6C064AB would be? I am waiting for them to show up and google wont help me with this.
MM's Orangest
2004 Mach 1 Mustang
B heads are considered by many to be better heads to use for boost, FYI.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
#9 | |
9.74@142
And even with that much boost/flow, the exhaust side of the B heads still need major work.
#10 | |
9.74@142
I was browsing Modular Fords in the 96-98 section and foind a more comprehensive list:
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
yes and no. the work on the exhaust side is easily done and not a whole hell of a lot needed. stock to stock, the c heads are a better all around head.
Threads Similar to: 03-04 heads on 1996 cobra
| 1996 cobra swap with 03 cobra heads and supercharger. | stan's96snake | 96-98 | 14 | October 30th, 2010 03:57 PM |
| 2003-04 cobra engine in 1996 cobra | hedgehog | 4V / SVT | 6 | December 9th, 2009 10:05 AM |
| help: 1996 mustang cobra | itsallme2500 | 4V / SVT | 7 | May 22nd, 2009 03:24 PM |
| 1996 Mustang 4.6GT 2V heads/intake | muzzie01 | 96-98 | 15 | May 26th, 2008 08:36 AM |
