1993 Mustang 5.0 LX
11.45@122.34
15's fit on a terminator?
my dad has an 03 cobra with the stock brakes on the back and was wondering if he can fit a 15x10 drag lite on the back without rubbing on the brakes..he is running the stock wheels on the front, but just wanted to get some slicks for the back on a 15 inch wheel to get a bit of a wrinkle out of them...so will a 15 inch wheel fit over the stock cobra brakes only in the rear?
No they will not fit without grinding down the banjo bolts on the calipers and even then its really iffy. Either get GT brakes on the rear, or use 16 inch rims. I personally dont like grinding brake parts, but thats just me. I went to a solid axle with Gt brakes.
Black 2001 SVT Cobra Solid axle "Good judgment comes from experience, experience comes from bad jugment" MM Cobra Club Member #1 |
2003 SVT Cobra
slight grinding will be required on the calipers and tie rod ends.
1993 Mustang 5.0 LX
11.45@122.34
ok thanx guys
9.74@142
GT brakes FTW
GT brakes and a solid swap FTMFW!
Moderator
That or put 16x10 wheels on it with 16" ET Streets. Will work just fine.
There's a reason Ford codenamed them the Terminator
i will trade my Solid axle for a cobra IRS if anyone wants
yes all stock
Noob Slayer
13.82 @ 101.09
might take you up on that
![]() 2003 Black Cobra 10th Anniversary 2.8 Kenne Bell Mammoth LC - Built SRA - T56 - E85 - Spray - Stock Longblock - True Forged Mach 5s 2004 Silver GT 5 speed - SOLD MM Cobra Club Member# 97 |
Im in Miami,FL
9.74@142
I might be able to find someone from SFL that would trade an IRS for your solid.
Are you serious about doing the swap?
i would do it if i had a place to change it
Sorry guess but I actually decided not to do it, I read up on it decided to go the panhard bar and torque arms route.
9.74@142
The best way to do the swap is with both cars at the same place.
Every IRS to solid swap that Iv'e down went down like this: I had the IRS out of the Cobra before the GT arrived. When the GT owner got there, we would remove the lolid and all that goes with it, swap the GT's pinion flange to the IRS, and install the IRS in the GT. The GT leaves and the solid gets swapped into the Cobra. If you are serios about wanting to swap for an IRS shoot me a PM. I can get you set up with a Cobra owner that wants a soild.
#16 | |
#17 | |
9.74@142
BTW, Terminator springs are a specific rate spring and can be cut to tailor ride height without adding any more ride harshness then you would by swapping to aftermarket lowering springs.
Threads Similar to: 15's fit on a terminator?
| my experience putting on 15's thus far | NUTCASE | 2005 - 2010 | 3 | February 5th, 2010 06:31 PM |
| peeps with M4's M16's and AR 15's ect... | navyman8903 | The Clubhouse | 9 | November 9th, 2009 10:21 AM |
| Can i fit 15's in my cobra | luis9988 | 4V / SVT | 15 | July 17th, 2009 12:37 AM |
| colors best fit the terminator? | 2oo3c0bra | 99-04 | 27 | August 7th, 2007 09:30 PM |
